good stuff to do while the head is off?
so my car is at the shop getting new valves,valve guides,gasket,head resurfaced,belts,rollers,waterpump,chaintensioner+pad, etc.
whats some other good stuff to do while the head is off?
i have an 88 944S w/ 80K
thanks!
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Under the Radar
Check the metal cooling pipes. When I had the head off my 83, I saw that one was ready to rot through, so i replaced it with a new one. Easy time to do it, and it would boost reliability.
Administrator - "Tyson"
thanks!
I have a literally brand new tensioner with 1 hour run time on it. Took the car around the block and decided to rebuild. I'll sell for $175. They retail for $250. I don't need it as I'm using a 924S block in my rebuild.
I've also got a used one in fair shape I'll "let go" for $25
do your water pump and rollers. since you are in there you dont want to go in again.
if you go crazy, do the motor mounts, which means you are next to the 20 year old oil pan gasket $100, which means you are next to the rod bearings $150, which means you will have your pistons in your hand and rings are nice $750. BTDT, then it was stolen a few months later.
The water pump is the biggie. order a new one from sunset. I dont trust rebuilt ones.
yea i was thinking of getting some "bottom-end" stuff done.. rod bearings more than pistons.
and then it gets stolen, right? :-/
hows the 944 selling going?
the rings were really a waste of $$ in my case but since he was holding the piston in his hand I figured why not. the car had 75k miles on it, and i was going to keep it another 100k miles.
if you want to save some $$ order the tune up parts and motor mounts from paragon and give them to the shop. i wouldnt order the parts related to the head or water pump. your warranty is their markup. He shouldnt charge much for the tune up labor since most of the stuff is out of the car already, or in the case of the wires, half out of the car.
