Supercharging..?
The Ltronic is fine. Seriously. Add a 5th fuel or water injector, it really is not that difficult - just dont hope for much with 10:1 compression. The system may not be "high resolution" but it is tunable just like any other, and decent compensations can be made with it.
If you have to use a supercharger, clearly you dont have the money for a Motronic, and arent expecting serious HP gains. Compromises, compromises.
Originally Posted by V2Rocket_aka944
http://www.andersonmotorworksinc.com...eroverview.htm
Site owner's name is John Anderson. He has the supercharger labeled for S2's but if you read the description its supposed to be for the 8valvers too.
Originally Posted by ehall
Anderson is the biggest scum bag to ever disgrace this board...with the debatable exception of Danno. Do a search.
You're either a liar or search is WAY too complicated for you.
I'd suggest that you read the following threads completely, though I suspect the words will be lost on you.
https://rennlist.com/forums/924-931-944-951-968-forum/117227-just-a-few-words-before-i-go.html
https://rennlist.com/forums/showthre...ferrerid=14903
here's another
https://rennlist.com/forums/944-and-944s-forum/149805-more-trouble-with-john-anderson-of-anderson-motorworks.html
and yet another.
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/137174-oilpan-removal.html
in this final thread the back story is that Anderson and his idiots installed David Floyd's rings UPSIDE DOWN! and didn't reimburse him either.
Starting to get the point?
BTW I got these in a simple search for the word Anderson.
here's another
and yet another.
lol, yes it is. Camaro, how much did that setup cost you?
And how much did it "get" you?
If you really want a supercharged car, find a turbo motor and stick a sc on it. It'll already be set up for boost and whatnot.
Rainman
I was thinking about that last night. Maybe I'd find some 951 pistons and swap them out.
Thanks for all the feedback, now I need another opinion:
Roots-type or centrifugal? Roots works more in the low-end, but these motors have torque down low for around-town driving, and power currently comes on about 3k. Centrifugal works in the higher RPMs, almost like a K26 snail. You guys are more familiar with the powerband of the NA motors than I...which would you rather have: low-end grunt or high-RPM power?
Hey Man
...You guys are more familiar with the powerband of the NA motors than I...which would you rather have: low-end grunt or high-RPM power?
Rainman
KuHl - I don't have AC
pj - I realize that turbo motors are far more tuneable for ridiculous amounts of power at minimal cost. However, I am only playing with this idea to be a little different from the boost crowd. I am in no way committed to this idea...I'd end up using parts off a 951 anyways (higher-boost pistons for example).
But the SCs make that whirr sound that I so love....
Hey Man
KuHl - I don't have AC ...But the SCs make that whirr sound that I so love....
Rainman
lol I have the belt whine and thoroughly enjoy it because people THINK its supercharged. However I think it would be better if I had a real SC; it would sound like I have TWO.
