Leak Help
Leak Help
Just parked the car two hours ago after being out in it for the day. Actually, it had been at the dealership getting some service (fixing fuel gauge, winshield washer fluid valve), and then drove it around some after. Had the full oil service done last week. It's been at a Porsche dealership three out of the last four weeks (PPI, then oil service, then the random fixes). Anyway, here's my pic. It's a small patch very close to the right front tire. Any ideas? Help!
First guess would be washer fluid since thats what was worked on last. If the leak is bluish or almost clear then its washer fluid.
What color is it? Near the passenger side tire is the power-steering system (reservoir, pump, and rack, etc.) If the leak is red fluid it's your steering system; otherwise it might be oil (brown/black) or coolant (orange/green/others).
If it's leaking and you're not smelling oil it is most likely lower on the engine. Open the hood and check to see if it is just below and behind where the oil filter is located , the sender is located near by the gasket has been known to leak.
