Cookie Cutter Weight? 15x7?
I searched everything- no luck. Even googled.
How much do these guys weigh? I've found about every other wheel but no Cookie Cutters.
14? I'll take it. I have both- cookie cutter and Fuch the same size.
No scale though. I'm afraid if I buy one to weigh, my wife will get the impression it's for her and then I'll be in the doghouse.
Hey Man
You'll have to keep looking. I sold all 6 CC's with the 83 last year. I was surprised how light they were. I've never weighed a Fuch on the same scale so the numbers could be whacked. The scale was for up to 200 lbs and I have a hunch the lower scale isn't as accurate sort of like torque wrench. They are getting harder to find out here between the 944 Spec cars and VW people using them.
I meant 14 sounds good enough- I have the 4 I need.
I have 3 Fuchs, 2 8" for rears and the one 7" for the front. The match I needed went for $321 on Ebay. So some $50/pr cookie cutters for fronts and the one Fuch will either get Ebay'd or I'll make a table out of it for the game room.
The Phonies on the car now are 8x16 all around and are boat anchors at 20 lbs a corner.
Hey Man
I don't think so. Boat anchors are the Mille Miglia 993 Cups replicas in early offset. With a 255-40/17 tire mine weighed 53# each...they were actually hard to lift. If you can find straight CC's for $50/ea. buy me a set. That's cheap out here for good ones that haven't been abused or curbed.
I got the last pair from a local 944 breaker- both are rough. I have stripped them both and plan on at least getting the bead clean for tires.
The 944Spec/Cup has become a hot deal in town. I know at least one shop is cranking out Spec cars and will probably be using CCs since they're cheap.
53lbs. I doubt my car would turn such a wheel.
