Toot Toot
Old 04-27-2007, 01:43 PM
Dan Shea
Dan Shea's Avatar
Default Toot Toot
Is there any common area's with the horn not working besides the ground for the ps rack? I have a brand new ground wire there, but still no horn.
Old 04-27-2007, 02:40 PM
Jay W
Jay W's Avatar
I had a horn not work and after I looked at all the wiring connections, removed both horns and reinstalled them I realized that the factory steering wheel was the problem. There is a brass ring on the backside of the steering wheel which makes contact with a contact point on the steering column. On my car the black vinyl cover on the steering wheel had popped over the brass ring instead of being tucked behind it, and the steering column contact was rubbing on the vinyl instead of the brass ring. You will have to take the steering wheel off the car to check this. I think I figured it out by using a multimeter testing for the ground on the connecting tabs of the horn button on the steering wheel. There wasnt any ground and I knew there should be.
Old 04-27-2007, 03:38 PM
Dan Shea
Dan Shea's Avatar
Do i have to take the wheel of to test it? or can i multimeter the horns themselves and check for signal?
Old 04-27-2007, 05:03 PM
GTSilver944
GTSilver944's Avatar
Mine stopped working after I reupholstered the steering wheel. If you pop off the horn pad (feels like you are going to break it when you pull it off but it wont) there are a few bolts with springs on them. Twist the bolts to see if one is loose. If one is, simply tighten it up and it should work.
Old 04-27-2007, 05:31 PM
Mamooguy
Mamooguy's Avatar
Also, the horn might just be busted.
Old 04-27-2007, 10:15 PM
mel_t_vin
mel_t_vin's Avatar
Dan,
The horn has a relay in the main electric box next to the brake booster under the hood. Standing over the electric box with the first row of relays closest to the fender, the horn relay is the third relay [silver] in the third row. Swap it with your fog light relay [same part] which is the first relay in the same [third] row to make sure your horn relay is actually working.
This is something you can easily rule out in less than 1 minute. Let us know how things turn out.
Allen
Old 04-27-2007, 10:22 PM
moorepower
moorepower's Avatar
That's certainly an astute diagnosis.
Old 04-27-2007, 10:24 PM
redmund
redmund's Avatar
Mine doesn't seem to work either, but when I press the horn, I can hear the relay click. No noise though. I am yet to figure it out :/
Old 04-27-2007, 10:39 PM
Mamooguy
Mamooguy's Avatar
Hey! Two years ago I went nuts trying to diagnose a horn problem, and finally surrendering I went out and bought a cheap-*** replacement horn at the local big-box store, installed it and sure enough it was like new.
Don't rule it out, is all I'm sayin'!
Old 04-28-2007, 05:17 PM
moorepower
moorepower's Avatar
No offense.
Sometimes the obvious answer is the right answer. It just sounded funny.
Question:"My horn doesn't work. What could be wrong with it?"
Answer: "Maybe it's broke."
Old 04-28-2007, 05:23 PM
Mamooguy
Mamooguy's Avatar
Don't worry, I wasn't offended. Much.
Old 04-28-2007, 05:42 PM
V2Rocket
Rainman
V2Rocket's Avatar
If it is busted you should take a trip to your local locomotive-parts barn...
Old 04-28-2007, 05:57 PM
Dan Shea
Dan Shea's Avatar
yeah thats the last thing i need is an airhorn
Old 04-28-2007, 06:00 PM
V2Rocket
Rainman
V2Rocket's Avatar
Honk it and people can hear you a half mile away
http://youtube.com/watch?v=TiWNw0A1Ijg
Old 04-28-2007, 06:02 PM
Dan Shea
Dan Shea's Avatar
i was about to look for that video...
Quick Reply: Toot Toot
