Headlight won't Pop up? Help!?
Just got my s2 cab back, driving to work lights pop up and work fine. I pull into my garage and the lights wont go down... The actual headlight works though. I manually lowered them and checked all the fuses.
On the fuse/relay chart it does not speficy a relay for the headlights. Is there one?
There is no noise at all when I turn the lights on and off so I am think/hoping its the relay.
1) Is there a Headlight Relay?
2) Where is it?
3) If that does not work...what else could it be?
Thanks!
2) Where is it?
Thanks!
there is a fuse for the headlight motor...may be called something else though like - lichtenopteratizionmuterizen or something.
and there is a relay on the side of the headlight motor under a rubber cover.
I think there are three seperate fuses for the headlight motor check all. I blew one of mine and I went down the list and thought that there was only one and then found out that I blew at least two of them.
When I checked out a link from "flat to the floor" on Parptarf's thread..they gave a great tutorial on headlight motors etc. there was also another link that referenced a "relay checkout" link..You might give that a try...Thanks, Tiger03447
