i have a problem, please help
Old 03-11-2007, 01:09 PM
devious944
devious944's Avatar
Default i have a problem, please help
so i was pulling up to a stop light . i pressed the clutch in and it went all the the way to the floor like there wasnt any pressure . i lifted it with my foot and now it will not go any farther than a inch . i took the line from the clutch master cylinder off and the pedal moved . so i know its not the maste cylinder.
i drove it home rpm matching. what does thi mean?
if the car still drives does it mean my trow out brng is still good?
please help , thank you
Old 03-11-2007, 01:19 PM
931guru
931guru's Avatar
You have a bad slave cylinder.
Old 03-11-2007, 01:29 PM
devious944
devious944's Avatar
so what are the chances my throw out bearing or clutch fork being broken?
Old 03-11-2007, 01:41 PM
Keithr726
Keithr726's Avatar
Clutch slave and master cylinders, this happen to me last week.
https://rennlist.com/forums/924-931-944-951-968-forum/334259-a-vent-thread-my-day-clutch-long.html
Old 03-11-2007, 02:02 PM
KuHL 951
Hey Man
KuHL 951's Avatar
The one oddball thing is after he pulled the pedal up he can't depress it further than an inch. I agree that either the master or slave might initially failed but lack of pedal travel would be a mechanical issue like a jammed TO bearing, locked up rod at the MC, jammed slave rod, or broken clutch fork. Doesn't sound good no matter how you look at it.
Old 03-11-2007, 04:13 PM
V2Rocket
Rainman
V2Rocket's Avatar
I doubt the fork would break under normal driving circumstances...I have one in my hand and its a pretty significant piece of aluminum. It wouldnt break too easily.
It's your slave cylinder...and while you're in there replace your master. I did it about 3 months ago and my car feels wonderful now
Old 03-11-2007, 04:16 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
definately replace the cylinders and the hydraulic line between them...
And, if that doesn't work, then get out your wallet.
Old 03-11-2007, 04:19 PM
V2Rocket
Rainman
V2Rocket's Avatar
Step:
1) Remove wallet from pocket
2) Open wallet
3) Find any credit/ATM cards, along with all bills labeled "Federal Reserve Note"
4) Throw into built-in 944 money-pit
5) Add gasoline and match.
Old 03-11-2007, 04:56 PM
Mighty Shilling
Wax On, Wax Off
does that work for you V2?
Old 03-11-2007, 05:06 PM
Keithr726
Keithr726's Avatar
I regret not tackling it myself for the $160 for parts. My total for bringing it to a shop added up to just over $1,000. Its obviously a porsche. I guess I also have less than a year on my clutch.
Old 03-11-2007, 05:10 PM
V2Rocket
Rainman
V2Rocket's Avatar
It's remarkable; the car runs perfectly after every time I do this. Sometimes I do it as preventive maintenance you know...hey, I'm reducing weight by getting rid of those pesky $100s.
Old 03-11-2007, 05:13 PM
KuHL 951
Hey Man
KuHL 951's Avatar
Originally Posted by Keithr726
I regret not tackling it myself for the $160 for parts. My total for bringing it to a shop added up to just over $1,000. Its obviously a porsche. I guess I also have less than a year on my clucth.
That works out to about $300/hour; where did you take it, Trump Porsche? That is absurd unless they charged you $600 in parts...it's a 3.0 hour job even on a 951.
Old 03-15-2007, 07:12 PM
devious944
devious944's Avatar
ok , i took it to Tom Charesworth tuesday to be fixed, i just got word today that it was a T.O. bearing.
so $250 and i will have her back in the morning . im just glad i dont have to buy a clutch
thank you guys for the help.
Old 03-15-2007, 07:35 PM
KuHL 951
Hey Man
KuHL 951's Avatar
If they can pull the trans, bellhousing, and replace the TO for $250...someone is smoking crack or it's not your your TO. If you get as far as the TO you might as well do a clutch job. Something isn't right with that quote.
Old 03-15-2007, 07:43 PM
devious944
devious944's Avatar
thats a good price .
Quick Reply: i have a problem, please help
