Trying to remove door side rub strip
Old 01-06-2007, 04:48 PM
smlporsche
smlporsche's Avatar
Default Trying to remove door side rub strip
the one that is on the outside of the door.
I've got the strip off but can't seem to remove the adhesive.
I've tried Goo Gone but it doesn't work.
Any suggestions short of a wire brush??
Old 01-06-2007, 04:54 PM
Techno Duck
Techno Duck's Avatar
Heat gun and plastic scraper?
Old 01-06-2007, 05:11 PM
shiners780
shiners780's Avatar
Hey Eddie, how did you get the strips off? And what's under there besides adhesive? Any holes/bolts/etc.? I'd love to take mine off, but not if I will need to have the doors repainted.
Old 01-06-2007, 05:14 PM
smlporsche
smlporsche's Avatar
No bolts or anything. I just used my wife's hair dryer on high and started at one end and began pulling. The adhesive is a b&tch!!
Old 01-06-2007, 08:04 PM
Wormhole
Wormhole's Avatar
3m adhesive remover and a plastic scrapper, that’s the easy part. Once all the adhesive is off you will be left with what looks like a magic marker. Hard to explain but adhesive remover isn’t going to get this off. You’ll need a good compound, a buffing wheel, and a lot of time.
Old 01-07-2007, 11:00 AM
smlporsche
smlporsche's Avatar
Thanks guys.
Sounds like I have some quality time with my doors comming up...
Old 01-07-2007, 12:36 PM
KuHL 951
Hey Man
KuHL 951's Avatar
If your paint is black or a dark color you will have no problem getting the strip to match. On a red, metallic, or clearcoated color the newly exposed paint can be much harder to match.
Old 02-24-2007, 05:23 PM
shiners780
shiners780's Avatar
How did this turn out? Any tips learned along the way?
Old 02-24-2007, 05:40 PM
apierce918
Addic
apierce918's Avatar
there is a 3m magic eraser that goes on a drill, its a round rubber disc, works great for that, and doesnt harm paint if used properly (dont go high speed in one spot for a long time) with the angle right, it comes right off
Old 02-24-2007, 06:40 PM
V2Rocket
Rainman
V2Rocket's Avatar
Rub strip = ?
Old 02-24-2007, 07:04 PM
shiners780
shiners780's Avatar
Where would I find that? Is it something Auto Zone would have, or would it more likely be in a hardware store?
Old 02-24-2007, 07:08 PM
BlueRiver86
BlueRiver86's Avatar
You may want to try using a very small amount of brake parts cleaner on a rag. That has worked for me in the past.
Old 02-24-2007, 08:54 PM
shiners780
shiners780's Avatar
I just tried a bunch of things: adhesive remover, citrus gel cleaner, brake cleaner, aerosol window cleaner, pb blaster, Motsenbocker's, and none of them worked. The products I used to remove the adhesive from the entire interior of the car don't touch this stuff.
I then tried Acetone, and it worked great! I put a little on a rag and gently rubbed the adhesive, it dissolved it to a point I could wipe the residue off with a second rag.
So...how bad is Acetone for car paint? It doesn't look like it is affecting the paint at all. Should I be concerned before going any farther? I only did a small 4" section so far.
I may get that 3M magic eraser just for kicks.
Old 02-24-2007, 09:55 PM
aribop
aribop's Avatar
Acetone is not good on paint. Stick with the 3M.
Old 02-25-2007, 01:59 AM
apierce918
Addic
apierce918's Avatar
anywhere that sells automotive paint should have it
just ask for a 3m eraser wheel, its already molded onto an arbor, mine was a skin toned color, and about 3 inches in diameter. i got it at Finishmaster
Quick Reply: Trying to remove door side rub strip
