NEED NEW WIPER ARMS AND CANT FIND ANY
the only place i found them was 944online and they are 33 dollars each
do you know of anywhere that has them
thanks chris
thanks chris
944 628 028 02 has 2 springs to hold the arm down and the blade on the glass at speed, the ones that came on mine only had 1 and these were a major improvement.
Paragon, Zims, Tweeks.
I paid $85 for the pair at Tweeks, Paragon has had them for $35 ea.
You are talking arms, not blades... correct?
I've got a set off my '88 951. I can get the part numbers and post a pic tomorrow if you want. They have blades on them, and I think I have a brand new set of blades still in a package.
I'll check it all out tomorrow and post back.
Originally Posted by AndyK
Would removing one spring make the wipers perfrom better (as in, no chattering)??
Mine chattered worse with the single spring arm... actually the key to that is good quality blades and clean glass.
I've read of some cleaning the windshield with Acetone.
Mine chattered until I replaced the plastic clip that holds the blade assembly to the arm. The plastic was worn and brittle so the blade fit loosely in the arm.
Tom
'87 951
Tom
'87 951
