LSD on an 83?
LSD on an 83?
did the 1983 944's come with LSD?
if not, i can purchase a rebuilt one for 200$ canadian, seems like a really good price.
how would i go about checking the quality of it (other than hooking it up! LOL)
cheers.
cheers.
Hey Man
You could order the 83 w/ LSD. If you can find a rebuilt TA, LSD or not, for $200 CD you should jump on that deal. I can't even find the LSD section of the transaxle for that cheap. You can turn the input shaft while holding the axle outputs and check for excess play. Trying to check the shifting on the floor is not easy.
Hey Man
Originally Posted by fork_included
how can i check my car whether it has LSD or not?
is there a stamp? can i check through the vin?
Originally Posted by KuHL 951
Will Spec 924 et you use a 'better' Torsen one or do have to use the OE disc type? Just curious
Torsen type are no goo for track use. Reason is they don't lock up on decel and this is a MAJOR benefit of the LSD. Lock up on decel in corner entry allows you to trail brake more effectivly thus gaining and advantage. The impact on accell out of a corner is minimal compared to stability underbraking from the clutch plate type LSD.
Hey Man
