Steering knuckle. MO3O or not?
I need to replace the front steering knuckle on my S2 race car. Is there a way to tell if it is a stock 951 or an M030 knuckle? Normally all Porsche parts have a full part number on them but I can't fine one on this part.
Thanks;
Don
Thanks;
Don
What brake caliper Don, big or small? Small brakes has to be regular 951 spindle. Big brakes could be either, depending on whether you are using an adapter. no adaoter = m030, adapter = regular 951
Big brakes but I am not 100% sure if there is adapter or not. Is there an easy way to tell?
That was not originally an M030 car, and Im about sure that it was upgraded to the 928S4 calipers with adaptors, not the full M030 hubs and spindles.
But post a picture and we can tell you for sure.
thanks Guys. I'm away on business and will post some picture when I get home. I think they are non M030 but want to check for sure. I need a new knuckle...
if it is F-stock with big brakes it should not have adapters . . . at least not technically. that is what DA told me
a picture would be easy to tell from.
Lifetime Member
Lifetime Member
This is a picture of an M030 spindle on my S2. As you can see the calipers attach via radial bolts as opposed to axial for normal calipers.
![](http://www.944s2.com/brakes/images/spindle_2.jpg)
