2.7l 8 valve head + 3.0l 16 valve head market value
Hi,
I just picked up a 2.7l 8 valve head in good shape for my S2 turbo project. I was wondering what current market value is on these heads. Also how much an S2 16 valve head with repaired tensioner (read cracked off mounting point and was welded back in) with 80k miles would go for. Thanks in advance, I'll let you guys know how much I paid for it after a couple of replies![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
-Nick
-Nick
Hey Nick, what's that "turbo poject" your doing ???
And thanks again for those spacers, I had promised pictures but you can't really tell they are installed. I can, but on the pictures it doesn't show.
Stephane
Stephane
Originally Posted by StyleLab
Hi,
-Nick
-Nick
Hi,
-Nick
-Nick
Just curious, why aren't you using the 16 valve head?
Stephane
Stephane
-Nick
yes, I did not go internal at all, but I'm only running about 5lbs of boost, but I did this on a fairly tight budget while still using good components. If I was running any more boost it'd be intercooled, and any more than 9psi, I'd go with lower compression pistons. But that starts a slippery slope on the way to complete engine rebuild where each step increases reliability and power potential. I'm not going there.
Any more than 15psi, I'd want a built bottom end and O-ringed head.
Wow, you've got your work cut out for you!!! Can't wait to see that complete!!
Aren't the pistons your looking for the same has here https://rennlist.com/forums/924-931-944-951-968-forum/307270-sunset-group-2-piston.html
Her has problems finding some also.
