Nautic Metallic L Y5Z (Nautic blue) How Rare? offer being made tomorrow!
Nerd Herder
see last post for update!
Well. I looked at another 944 tonite.
Option codes: 944 332
Thats it. Barebones 88 944NA.
Interior 6 - exterior 7/8 137K miles.
NO records. So it'll new a Waterpump, belts, tune up.. etc all asap.
(roughly 600 $ in parts )
Normal wear and tear - some bondo (not a lot) rear qtr above taillight, in front of Drivers side rear wheel. Rocker panel on drivers.
Decent respray Nautic blue.
a touch of rust behind the rear pass wheel. normal sandblasting of paint around wheelwells and front fascia.
PO has buggered up: sunroof- bad manual conversion (sheesh) body panel fit is OK, needs some tweaking. Headlights need aligned.
Clock- toast. Waterpump, leaking out the weep hole.
Overall, I'd give it a 6.
Mechanically, a 7/8. Clutch is nice, power like a normal NA, no smoke. No oil leaks. No PS leak (!!??)
Newer pair of cheap azz tires on front, older cheap azz tires on rear. suspension OK, not soft- normal. Motor mounts OK, a little greas present on the CV's, new exhaust (not oem)
The good: ODO works.
The question: What would you give for it?
Nerd Herder
Uh.. Rock. I meant as in , what price would you offer the current owner for it.
You'd give a leg alright, your 3'rd one.
Lazer Beam Shooter
Oh i would give a 3rd leg. My ****** is long enough to be considered a 3rd leg. All I have to do is look at a playboy and I can pogo stick anywhere.
Originally Posted by Rock
Id give a leg. Cuz I aint got no legs... or no brains. Nice to meet you, hi my name is.... I forgot my name!
Bad body, good mechanicals, needs maintenance...
2750? Only since its an 88 with the higher compression engine....
if it werent an 88 I would say 2500 or 2k
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
I have a Nautic Blue Metallic '87 and I haven't seen very many others. I think they only used that color in '87 and '88.
Anyways, it sounds a little beat up -- no more than $3k. But '88 is a plus for the high compression engine AND the short 5th gear.
Nerd Herder
It'll be a double duty vehicle - second daily while 924S can get some overdue rehabbing, and some goodies; part time auto-x and track use.
Thanks Joe- It's the first Nautic I'd ever seen. Tan interior.
Nerd Herder
Oh yeah- no spare, Factory Blau not working, Rear carpet hatch is toast.
No records, no receipts.
Forgot to check: Inspection hole for clutch (Maybe still rubber center?!) AC not checked, headlights not checked- Headlights are sitting low when down, and hood seems bowed..
Note to self- check this when making offer..
Nerd Herder
Thanks Danny- It may be in your garage soon for a water pump , belts..
Do you still have the old tan seats??
Sounds like a really abused car. I'd avoid it unless you are looking to turn it into a track car. With everything that is wrong, most likely there is 2-3x more wrong with it as well.
~$2K or less.
Just save yourself some money, and spend $5k on one that has been taken care of. Its been repainted, so the rare color doesn't really mean too much.
~$2K or less.
Nerd Herder
WELL, I'm making my offer tomorrow. car was originally $5700 before the water pump went, I told the PO to check E-bay for realistic prices.
I'm thinking $2700 is the magic number, I'm starting on the negotiation at 2 grand....
This would be watercooled Porsche #4 for me.
Wish me luck!
Wish me luck!
