i want a new knob!
i want a new ****!
i put a new shift lever in. love the nice new feeling when rowing thru the gears. now i want more! who's istalled an aftermarket ****?
I have one and there is such a difference.
Originally Posted by SchnellerUmsetzer
I think, since you like shifting, that you would really like a short shifter kit. Schnell B&M ect sell' em.
I have Schnell short shifter
I bought it through
www.vertexauto.com
SKU# 90
I think that B&M might have! I know that schnell still does!
I bought it through
www.vertexauto.com
SKU# 90
There was a post on OT 'bout a guy that got a new ****...
It was stuck in "fifth gear" for several years...
He got around $400,000 in compensation IIRC!!!
Jim 1987 944S
Jim 1987 944S
Honestly,
A Username like "Robin" and the whole **** concept went up side my head too, but being professional is important!
I'm going to revive this thread from the gutter w/a question for you guys...
Is installing the short-shift kit a DIY project, or do you need a professional? I drove a 944 w/one & you're right, it was amazing, the difference. Felt so crisp.
Also, would that be the time to change the ****/boot, "while you're in there"? Mine is ripped, and I'd like to put a new one on.
This sounds like a project I'd like to try if it's reasonable, but I don't want to get in over my head, or screw something up. Any thoughts on level of difficulty and time consumption for something like this?
TIA!!!
TIA!!!
The Short shift kit is not that hard of a job. The schnell kit actuall comes with detailed instruction. The Mechanism is actually located on top of the Transmission in the rear of the car. It to do the job correctly you should use wire and Loctite when installing. If not the bolts could vibrate loose and then no shift.
www.clarksgarage.com is a good pick. I will post a picture of the item you are replacing.
In
TRANS-07, Transaxle - Checking, Repairing, and Replacing the Shift Lever and Shift Linkage
In
Oh, so you're not actually anywhere near the ****, are you? Oh well, 2 separate projects, then. The short-shift kit definitely being the priority! Any idea on estimated time for the kit install? (I could probably have access to a lift, and experienced mechanical assistance.)
As for the **** project, and back to the original point of the thread, any pics of aftermarket installs?
