thinking of selling the 951
Thinking of selling the 951 and getting a Mini cooper S or Boxster. I need a car I can drive on a daily basis, If I keep the 951 I think I'll end up with a speeding ticket soon : ) .
I can't afford the boxster S, Any opinions?
Thinking outside da' bun...
For that jing, what about an Evo VIII. Or did I just start a ****storm.
Here's the deal, I drive to your place, nice 5 to 6 hours drive, we switch cars, I drive back. All doable, and you end up with a nice S2 which should be easier on the tickets level.
... Wait a minute, I don't even know what your 951 looks like!
I'm assuming it snows alot in Toronto, being so close to Detroit and Buffalo. I'd go for a WRX. Comes in three levels for your pricing and performance ambitions. Plus AWD.
Car has 186,000 km. 1986 951 , Mechanically sound, clean in and out. 20 years old so qualifies for classic car insurance ,alos no smog test required so Cat can be deleted (canada only). All electrics work. Needs rubber - flat spots on these bridgestone .
Work done,
Koni yellows, springs
BB Tri flow3" pipe
Venturi delete, all vacuum lines replaced
Vitesse AFM chip
3 bar FPR
17" Porsche Boxster wheels
Lindsey wastegate shim
narrow gauge a/f
sard boost gauge,
All new - TPS, brake pads ,drilled rotors, plugs, fuel filter, Water pump, belts,rollers ,front seals, oil sensor, fan termo switch ,low temp rad thermo, rad pressure cap, sway bar bushings, hood crest, tranny fluid , rear hatch shocks.
New 968 castor blocks going on soon.
Sure I'm forgetting lots of things. It's appraised for 17000 cad. If I sell I 'd have to get at least 15000 cad.
Work done,
BB Tri flow3" pipe
Vitesse AFM chip
3 bar FPR
narrow gauge a/f
sard boost gauge,
