Reques Pics- 1986 951 or 944 timing belt tensioner pics or timing belt pics
We need pics of the timing belt area. We need to find out why our timing belt tensioner isnt sitting right. Any pics of the timing belt area would be greatly apprieciated. Thanks!
What exactly is it rubbing on? Can you verify the part # for the rolller.. 944.105.631.04?
Can you do a farther away picture showing the general area with where you are working? I spent a good 8 hours total staring at the front end taken apart having needed to do the belts essentially three times due to stupid errors i made. Granted my engine is a bit different with the spring tensioner, but maybe we can catch something wrong.
Is it just rubbing on the rear belt cover? The stud that the roller mounts to just has the jamb nut and the roller goes directly on that without any spacers. You may want to put a straight edge between the cam and crank gears and see what you have.
The rear belt covers on many cars have been "field modified" to accommodate the updated water pump, so maybe it was not clearanced sufficiently?
It turns out I am missing the "Shouldered nut" P/N: 944.102.243.00 seen in the picture below from PET..
I wonder if the dealership will have it?
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
![](http://devansky.com/eric/msg/951beltprob/doh.jpg)
