What do These Pics tell you about my engine
Got Nothin'
Finally found time to post pics of my engine after I got to the headgasket. The gasket itself was OK, there were no visible (to me) places where it seemed it was leaking. The cylinders did not have any coolant in them, although it was several days between draining the coolant and removing the head.
What I am concerned about is the buildup on number 1 and 4 cylinders. There seems to be tons of carbon there. The other 2 are not as bad. The car was running like total crap when cold, sounding like it was on three or less cylinders. Once warm it ran great. I convinced myself it was the HG so now I don't know what to think. Appreciate your opinions on the appearance of the engine.
The Cylinder Head
![](http://forums.rennlist.com/upload/cylinder_head.jpg)
Number 1 Valves
![](http://forums.rennlist.com/upload/1.jpg)
Number 2 Valves
![](http://forums.rennlist.com/upload/2.jpg)
Number 3 Valves
![](http://forums.rennlist.com/upload/3.jpg)
Number 4 Valves
![](http://forums.rennlist.com/upload/4_copy1.jpg)
The block
![](http://forums.rennlist.com/upload/block.jpg)
#1 Cylinder
![](http://forums.rennlist.com/upload/block_1.jpg)
#2 Cylinder
![](http://forums.rennlist.com/upload/block_2.jpg)
#3 Cylinder
![](http://forums.rennlist.com/upload/block_3.jpg)
#4 Cylinder
The Cylinder Head
Number 1 Valves
Number 2 Valves
Number 3 Valves
Number 4 Valves
The block
#1 Cylinder
#2 Cylinder
#3 Cylinder
#4 Cylinder
![](http://forums.rennlist.com/upload/block_4.jpg)
To make it easier for people, and prolly get a lot more views, add [img] in front of the image location, and [/img] after, like so but with NO spaces:
[img] http://forums.rennlist.com/upload/cylinder_head.jpg [/img]
it will turn into this:
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
You have a lot of carbon build up. Have you done a compression test to see if you have bad rings? Last motor I tore apart had that much carbon and bad piston rings, causing carbon build up because oil was being combusted with the fuel.
....or you are using 80 octane
Canadian Yankee
I agree it looks like you may have bad rings, that or bad injectors as well, if the injectors are stuck open it can cause carbon buildup as well, I say check your rings and your injectors
Brandon
Brandon
Wax On, Wax Off
Well, FWIW, there are a lot of threads about cars that don't like to run when cold. it's a fairly common issue with the 944NA... soooo, that may very well be what you were experiencing... for the most part, that looks like it's in great shape!
Fuse 24 Assassin
Fuse 24 Assassin
look at your #3 compared to the others! You have either very leaky valve guides or you may need to re-ring your block. Did you compression test???
That puppy looks like it was WAAYYY rich on 2 cyls.
Rings and valves need a serious look-see. As the Stig said - did you do a compression check before your teardown?
I'd also recommend an oil analysis from Blackstone. It can give you a bit more insight in to the internals.
you didnt beat the car enough to blow the carbon out of the cylinders! You need a bottle of inj. cleaner- or some e-check in a bottle that works great for cleaning carbon out. Then beat it alittle harder.
Man, I must be blind. That looks like something on the gasket, but I guess it could be a crack in the gasket.
Looks like he is burning some oil from the rings as the bottom edge of all 4 pistons is clean, but I wouldn't lose any sleep over that.
My best guess would be an injector problem on #1 and #4.
