This KILLS ME!
My local dealer wanted $2200AUD ($1628USD) for a clutch & pressure plate. I'm still giggling like a girl about that one!!!!!
Managed to get one (OEM) on Ebay for $450AUD. The dealer prices are a joke! how do they justify that kind of mark up??
WOW- i got my j-boot brand new from paragon-products for like $35! Ive seen entire hose kits for around $120!!----ok i guess if you have a turbo then the boot is more like $96. Cant remember who had those hose kits....
I did a little looking around (not a whole lot mind ya), I heard my swiss has a kit, and LR, but from what little I did see and hear of them, its just the 5/32" silicone hose kits, not the larger pre-formed hoses. Those larger hoses are the hoses that are gonna get ya, not those little sissy ones.
I finally finished up this morning getting all those large hoses straightened out under the intake (I hope). Yesterday, I couldn't seem to keep my head straight long enough to get much of anything done! I confuse easy sometimes!
I ended up replacing two other hoses under there besides the one above, with brand new formed hoses (THANKS, MICHAEL!). I was able to re-use or find better fitting hoses leftover from parts cars here. I found out that some PO had mickey-moused one of the larger hoses to the cold idle valve, thus stressing this hose pictured above. I found most connections loose and moveable on their attach nipples or attach points, some cracked, broken under the clamps, some hose ends I could trim the ends off, and make work, some I could just use bulk 3/8" fuel injection hose to replace them with. I've got a pretty good selection of those Norma and Gemi hose clamps, so I was able to size down the clamps to get more of pinch on some places that obviously had to large a clamp on them in the first place (even if it was a new hose). I looked at using 90 degree fittings, and bulk 1/2" hoses under there in places, to avoid using pre-formed, and decided it was definately not gonna be a quality, long term solution. There just isn't much room for this kinda thing. That type of hose/fitting attempt, looks to me like it will result in melted, worn through hoses in no time due to vibration and contact with top of balance shaft housing, so I didn't go that route. I should be all good now.
