THERMOSTAT QUESTIONS
hey guys! i just installed the new thermostat (that darn snap ring), and flushed my coolant, bled all the air out, and put in new coolant (50/50 phosphate free + water). so i took it out for a drive. The car warmed up normally, but after constant driving, the bar stayed at the 3rd tick mark consistently. (BTW, i got a 180 F thermostat). Then as soon as the gauge read above the 3rd mark, the fan would turn on. Is this normal? (for it to run at the 3rd bar for a 180 F thermo) thanks!
That seems a bit high for a 180 F thermostat. Check to make sure your coolant temp sensor connections are clean. If that's not the problem, I suggest finding somebody with a temp gun and see if your radiator has hot and cold spots(indicating a plugged radiator).
No, I would not call that normal. Was it a Wahler brand? There are some cheap-o aftermarket t-stats out there. Are the fans coming on when they should? Is the radiator blocked with debris? Are you sure you fully vented the system?
the fan still comes on at a little above the 3rd bar gauge. the brand was "Stant" Looked good and i tested it in a pot on the stove,a nd it opened at 180 F.
also, i drove around for a bit, got the coolant nice and hot, i radiator hose that connects to the bleeder screw, and it was very hot. then i touched the resevoir tank, and it was dead cold....is something not flowing right?
also, i noticed that when i was warming up the engine for 10 min, to get the coolant loop goin, even when the temp reached the middle, my heater did not work...but then when i took it out for a drive, the heat came on...so i dont get the point of turning the heat on full blast if you need moving air to make it work.
Originally Posted by XxKHxX
the brand is Stant, the fans come on at the normal 3rd tick, the radiator seems pretty clear but has rocks stuck between some fins. What do u mean vent? vent as in gettin the air out? well, i loosed the bleeder screw, squeezed the radiator tube until water shot out so that i was sure air wasnt int he system....help?
