Stig's Official Engine Rebuild Thread
#137
Addic
Originally Posted by TheStig
you guys just really want me to pull this engine from the bottom? We should start a pool to see who thinks I'm going to have trouble pulling it from the top and who thinks it will be a breeze for me
#139
i did alot of research before pulling the engine out.people said top and people said bottom.starting a poll isnt a bad idea.from experience,i pulled the motor out the bottom.my first ever engine pull too.suspension comes out real easy,an hour and a half TOPS!!then lift the car 22 inces,drop the cross member,unbolt motor mounts,torque tube,pull forward to dis-engauge and lower it onto a creeper and roll it out the side of fender.btw,the number one tool to have when going out the bottom is a cheater pipe.it makes things ALOT easier.
#140
Andy,
The problem with a poll, is most of us (myself included), have only pulled the engine in tbhe 944 one way, so it is hard to give a really valid comparitive opinion. For example, I think dropping the engine was very easy. However, I can't really say for sure if I would have found it more difficult out the top.
However, Zero10 (see post 129) has done it both ways and I would be inclined to pay particular attention to that.
At the end of the day, you will get it out either which way.
#141
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Ladies and Gentlemen...
I have my block back and the cylinders are perfectly honed and the cleaned. This motor looks BRAND NEW like it stepped off the assembly line at Neckarsulm!
I will shoot some pictures tomorrow and post them ASAP!
Oh and BTW, I got my car 20" off the ground and will be taking my motor out from underneath....with no filler tube and no intake manifold in the way!
#142
You can sneak it through the side if the front suspension is off. Lets you have the car around 15" off the ground instead of 20". If you really want to know how fun it is to go out the top, get a prybar, and scrape the heck out of your frame rails with it, then it will at least look the same.
Hahaha, this quote cracked me up. Maybe because it's almost 6AM and I am still sleepless, maybe just because he said both ways... I dunno
#144
maybe i missed somehting somewhere in the thread but i noticed youve already got the crank bolt in but you left off the power steering pulley, yet you still have a power rack. are you planning on just running the power rack as a manual? thats what i decided to do and ive got the arm mustles to show it
#146
isn't rebuilding engines fun? that clean block looks so sexy on the engine stand!
i was going to suggest removing all those hoses and lines but i see you got the engine shoehorned in there. good luck getting it going. that first oil leak will be a bummer, but you'll get it all figured out.
#148
The pics show the engine in, out, then back in, then on a stand...
Perhaps he means the oil leak pictured after the series of the engine being out of the car?
Anyhoo, looking good. I forgot alll about this thread. Isn't it nice to tension the belts with the engine out of the car?
#150
Fleet of Foot
Just to clear up a little confusion... the "new" engine isn't completely assembled yet, but should be back in the car by the end of the weekend, right Andy?? The bare shortblock is the new one.
