I think I had piston valve contact.
no, those are factory markings to prevent contact. see my collection of rebuild photos for clean pistons. there is no piston damage that i can see. why do you think there was contact?
Stripped belt, no compression.
So what is the trick to removing the valves?
EDIT - in that case you may have damaged valves. need to pull the head and/or teardown the engine to find out.
to pull valves you need a valve spring compressor. my mechanic pulled my valves after i removed the head, but peterjcb recently built his own valve spring compressor
Campeck Rulez
hehe its always worth a laugh when you see stuf flike this.
(no offense)
how about the guy that got scared cause there was coolant in the engine? :snicker:
(no offense)
quiet down kiddo
