924S3 Update
#137
I don't think I mentioned that I ended my DE about 15 minutes early because my brakes started squealing like a pig. I looked at the front drivers side and it appeared that had almost blown through the pad (third day on KFP golds). Well, when I got home, I went to pull the pads only to find that I had blown completely through the passenger front side
(see photos below). I had been thinking that a brake upgrade was needed, so I bit the bullet and called Travis and Rennbay. These bad boys showed up today (see below), best of all, they fit under the 15" phonies
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
#138
i just got the KFP golds and am anxious to try them out. i'm not surprised you overdid your brakes with such a large increase in power that they had to tame.
your car is turning out to be quite a track monster - suspension, motor, now brakes. do you have a full cage in it?
#139
I guess I don't understand why changing the calipers would help cure the problem of "blowing through" the KFP Golds? Did you change brands of brake pads when you changed the caliper?
#140
#141
I had a custom roll bar installed last year (Kirk Racing) that will be built out into a cage before the end of the year. I am also trying to decide on the fire suppression system. If all goes as planned my first race will be with the PBOC in March at Barber.
#142
Well, I got an email today asking me how the 924S? was running so I thought that I would pull up this old thread. I can't tell you how much fun this car turned out to be. If you've ever thought about doing the transplant - do it. In fact, I have most of a spare 968 engine that I'd let go for the right price.
Here's a clip from a DE at Road Atlanta a few weeks ago. Click here
#143
Cool Video. Looks like you're hitting like around 100 MPH on the long straights over there. Is that about right?
As light as the 924 is, with the largest / strongest engine ever put into the line, it should really accellerate well! Sure looks like it on the video.
#144
Well, I don't have a speedo, but a friend of mine with an E46M3 had us clocked at 145 (speedo indicated) just before braking going into 10a (end of long back straight). I wasn't able to hit that consistantly, since I had to have a good run out of 7 to get there.
If you want to know where where 100 mph is on the track, watch for the shift from 3 to 4th, that typically occurs between 97 and 102 based on my gear ratios and tire size.
#147
Well done!
#148
Originally Posted by eohrnberger
Zounds! That seems awfully fast for a DE. Seems more like what you'd expect in an SCCA race of some sort. That is going fast!
Well done!![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Well done!
#150
Originally Posted by Friendan
Lemming, I think you should invest in a larger rear view mirror for your car.
Another clip, this one from Little Talladega
