New KONI Shocks = :)
Well it only took two days, about an hour for the rear shocks. and then about four hours to figure out how to do the first front shock and then only one and a half hours to finish the second.
Here are a couple shots of the rear shocks being replaced.
The tube that your new konis sit in was the "shock" before. Now it's just a housing for your konis which conveniently sit inside of it. If you cut open your konis they would look similar to what you pulled out of the strut originally. afaik.
the old shocks were probably blown and leaked into the tube. mine did.
Woah, you have the right type of wrench to hold the top of the shock to loosen it?! Lucky.
Originally Posted by cjeckert
Oh and btw why did oil drain out when i removed the cap that holds the shock in the tube?
I need to do this before I get my alignment, but I don't even have a vise anymore!
That aside, can you put Boge or Sachs cartridges in the front tubes or do you have to use Konis?
