My Fixed Headlight Mod - Wired Up
Old 07-22-2005, 10:44 PM
  #46
MPD47
The Carnage King
MPD47's Avatar
Small update for today, wired up the driver's side (Still have to build the passangers side) minus the city light in the high beam as I dont have the connector for it handy. I'm mid-progress with the lexan cover, should have an update with that tomorrow. Damn I forgot how bright these things are...
Low
High
Originally Posted by tifosiman
Damn, Mike, those look great. Honestly I have never liked any of the non-stock lighting projects on here, always thought that stock pop-ups or the GT kit were the only real ways to go. But I like that a lot. There is a local guy here who has a similar set up on his 911SC racecar that has a Moby-Dick-like body kit on it, and it looks good on his car, and since the factory decided it was OK to locate the main lights down low on that car (racecar, not a streetcar, but hey, it's my rationalization so let me have it OK ), I see no reason why any purist would want to scoff at this idea (an updated version of the same). I can't wait to see the finished product. If you came up with a nice tutorial, and template for the brackets, it would be a real service to others on here.
Thanks! That means alot coming from you. I've actually got the templates basically created on my computer already. I tweaked them a bit in real life but I'm sure it would be easy enough for me to update them and put them online. I know there would be slight tolerance differences per car, but hey, we're all 944 owners I'm sure you guys can figure out it. Plus I have photos from almost every step of the way.
Hey, in regards to brake ducts....................I have been toying around with another idea that might work for you. Do you still have the factory ducts left in the nose on the outside areas of the grill? The squarish ones that are shaped sorta like an "S" that shoot air toward the metal deflectors? I have an extra pair of these, and I thought a good alternative idea is to cut them a little short (right after the first bend), then add some material (fiberglass or something else) to the back to diffuse the square duct down to a 2" round outlet at the back of it. Then attach this to a hose and backplate kit from OG or any other vendor.
Hmmm sounds like I know my next project. Great idea tifo!
Old 07-23-2005, 12:48 AM
  #47
Lead Foot 944
Lead Foot 944's Avatar
NIcely done.......Deff....One of my favorite turbo's on the boards....Love the custom fab work.....Keep it coming.......NOw make me an HID conversion for my fogs......!
DAmian
Old 07-23-2005, 01:37 AM
  #48
TRP951
TRP951's Avatar
Looks great Mike are you going to put some kind of cover on those like the stock fog cover?
Old 07-23-2005, 05:36 PM
  #49
Zero10
Zero10's Avatar
Stupid question time, but do those work as well as a fog light in a foggy situation?
They might since they're so low.
They look hot. Plain and simple. Plus the covers would be a pretty simple thing to build, since there are already some mounting holes in there. Just add some brackets, and a curved piece of lexan. You could probably make a plaster negative of the original fog light lenses, or maybe fiberglass, then just heat the lexan, and form it with compressed air, or vacuum form, or something.
Perhaps you already have a plan for this?
Old 07-23-2005, 05:48 PM
  #50
Macfreak007
Macfreak007's Avatar
HOLY COW! I really can't wait to see the finished product, WHEN i get my turbo I will be definately doing this. For now I have to stick with a euro front bumper and euro factory driving lights. A great project, this should definately be something that you keep bringing up, at this thread to your sig line or something, excellent work!
Old 07-26-2005, 10:44 AM
  #51
testarossa_td
testarossa_td's Avatar
Got any more work done?
Old 07-26-2005, 10:50 AM
  #52
pearldrum944
pearldrum944's Avatar
That one-piece header panel is awesome...
Old 07-26-2005, 02:30 PM
  #53
Mike B
Done With Sidepatch
Mike B's Avatar
Nice work Mike!
Old 07-26-2005, 03:19 PM
  #54
M758
M758's Avatar
Ohio must be an odd state, because I have never had an inspection done on any of my cars.
Same here in Arizona. No inspetions... They do required emissions check every couple years on older cars, but nothing beyond that. They don't even require that if you not in the Phoenix area. (not sure about Tucson)
Old 07-26-2005, 03:51 PM
  #55
azmi951
azmi951's Avatar
Tucson requires emissions for anything 67 and newer.
My chevelle ('66) doesn't need to go through emissions but my buddies 67 Chevy 2 does....go figure.
Old 07-26-2005, 04:13 PM
  #56
MPD47
The Carnage King
MPD47's Avatar
I've been working on the lexan covers, mounting them is a pain! I'm also wiring it up so the lows stay on with the highs. There should be an update with some new photos tonight or tomorrow.
Old 07-26-2005, 04:17 PM
  #57
theedge
theedge's Avatar
What wattage are those bad boys? Once theyre done could you post a pic in a parking lot, showing what they light up (throw) and stuff?
Looks like an awsome project!
Old 07-26-2005, 05:57 PM
  #58
MichelleJD
Jane Bond 007
MichelleJD's Avatar
Sweet! Wanna buy back your old euro fogs and make me a set of those?
Old 08-01-2005, 10:31 PM
  #59
MPD47
The Carnage King
MPD47's Avatar
Small update for today, got the second set of lights mounted up, just copied my template for #1, had to hammer a SLIGHT piece of metal right next to the bumper core support (nothing structural, I could've bent it with my hand.) More photos to come tomorrow when I work on wiring/lexan.
Old 08-12-2005, 03:06 PM
  #60
testarossa_td
How are the lexan covers coming along?
Quick Reply: My Fixed Headlight Mod - Wired Up
