Opening in clutch housing for TDC mark?
#46
Wow, I was looking in the wrong spot
this website helped alot
http://members.rennlist.org/dan10101...ting_belts.htm
but, I noticed there is a kind of big rubber tube connected to a conical black thing..but the other end of the tube is not connected to anything
anyway, I'm gonna try and see the OT mark..its not there now (and the cam is at TDC..)
#47
Dowel is pretty easy and is very accurate, but I'd make damn sure it's long enough that it can't fall into the cylinder at bdc. Why not use a screw driver like the rest of the world? It's not like you're going to put a big scratch on the piston or anything.
#48
**** that OT mark.
Just turned that motor over 3 complete revolutions of the cam and that mark is nowhere to be seen. I will just use the cam @ TDC with the dowel and be done with it.
Peckster-- Its very long and to be extra safe, has a curve in it so even if it did fall, it would be stopped![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Mike
Mike
#49
I've had a tougher time seeing the "OT" than the scribed line that you line it up with.
Have you tried spraying it with brake cleaner? BTW, don't use anything else since you can screw with the friction surface.
I personally wouldn't want to just guess or to even use the dowel trick, lest you get off a tooth. On some cars it can be pretty infuriating trying to find the line.
#51
I understand (for the most part) how the engine works. Before I just never thought about my understanding of it would have a valve opening more than once during the 4 strokes. I could swear though that at times I couldn't get the mark on the flywheel to line up. Like 2 weekends ago when I pulled the cam tower off. I lined up the cam mark and the flywheel mark could not be seen. Spun the engine again and put the mark exactly where it was before...there the mark was in clear sight. I guess I just need to mess with it myself to finally see it.
#52
Kuhl951-- I hope you understand that was just some frustration being vented. Spending all day in that ridicously hot garage..working on a car that I can't find my hands anywhere in..just frustrated! My apologies!
Mike
Mike
#53
Hey Man
Mike
Mike
Steve
#54
I was sure that my 83 did not have the "OT" stamped on the FW unitl I pulled the FW off during a clutch job. Sure enough, it was there. I put a little white paint on the edge of the FW and wiped off the excess leaving the line and "OT" very visible through the hole.
Also, about the rotation of the cam and crankshafts, look at the size of the sprockets. The crankshaft sprocket that drives the camshaft sprocket is exactly one half of the circumference of the camshaft sprocket. That may help to understand that the crankshaft turns twice for every rotation of the camshaft.
Finally, using the "OT" mark is the most precise method of setting the engine to TDC. The FW is much larger that the camshaft sprocket. So it can be more precisely aligned with the mark. In other words, the "OT" line is a very small protion of the FW circumference. And, of course, belt tension can cause the camshaft alignment mark to rotate slightly, too.
#55
Hey Man
Originally Posted by 83na944
I was sure that my 83 did not have the "OT" stamped on the FW unitl I pulled the FW off during a clutch job. Sure enough, it was there. I put a little white paint on the edge of the FW and wiped off the excess leaving the line and "OT" very visible through the hole....
Streve-Weren't you one of the the other persons doing the clutch the same time as me? There were 3 of us bitching and swapping tips for about two weeks there if I remember right.
#56
Looks like its either my timing was off or I got a serious vac leak.
You called it Steve(kuhl951)!
Tommorow I'll check for vac leaks and bring it to TDC (or try to) and make sure everythings lined up. If not, I'll have to redo the belts, right? Oh well, practice makes perfect
Good luck on the transfer case! That and transmissions are the most intimidating things to me. Grab a beer when your workin on it, I'll setlle for my water (youngin here!)![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Thanks for the help guys!!
Mike
Mike
#57
I use the cam marks for rough alignment. As I said, when the cam is aligned, the flywheel mark should be in the window. Then it's just some fine adjustment needed to get it perfectly aligned. I've done 4 belt jobs and this is the method I've used each time.
#58
Hey Man
Good luck on the transfer case! That and transmissions are the most intimidating things to me. Grab a beer when your workin on it, I'll setlle for my water (youngin here!) ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Mike
Mike
![](http://forums.rennlist.com/upload/325tc_splines2.jpg)
