Rattle that goes away when clutch is depressed, what could it be?
I've got a rattle coming from under the rear of the car, that goes away when the clutch is depressed. It sounds like its coming from the tranny area. The car runs and shifts great. What could it be?
thanks in advance.
Jon
thanks in advance.
Jon
Originally Posted by Z-man
Throw out bearing.
Jon, I have the same noise on my car. It is also an '89 S2 with a few more miles than yours. My problem is that the main shaft bearings on the tranny are worn. I have play in the shaft. I'm planning on a rebuild so I'm not too worried about the noise. My car, like yours, still shifts fine.
Torque tube bearings.
83 944 = It's NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts
and/or cam chain and tensioner?
The 83
The 83
Z could posibily be right on the TOB since those noises can be hard to track with the torque tube transfering the sound unless you use a mechanic's stethoscope.
However, our transmissions do make some noise if you leave them spinning in neutral. Even good ones. Sort of like marbles rolling around. If it isn't too loud I wouldn't worry about it.
Thanks guys, I was thinking it was the throw out bearing, but the area the sound was coming from confused me. I'll check it with a mechanics stethoscope.
Albert: Nice car, where did you buy those replica turbo wheels?
Hey Man
Does it make the rattle at idle and out of gear or only moving with clutch engaged? Noises travel all over that torque tube and it's nearly impossible to find them from inside the car.
The parts that stop spinning when you depress is everything behind the flywheel. I had a worn out pilot bearing (seized) and wore out the tip of the torque tube shaft so it rattled like crazy. It could also be the throw out bearing, torque tube bearings, or input shaft bearings in your transmission.
Hey Man
Originally Posted by 7thStranger
What would cause a clank everytime when you let up on the clutch?
A failing rubber center clutch does exactly this. A really really worn ring and pinion can clank but I bet it's the clutch.
Originally Posted by aribop
Z, his noise is comming from the rear, throw out bearing is in the front.
