Purple Power!!
Old 05-21-2005, 04:37 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
Default Purple Power!!
Before:
Old 05-21-2005, 04:41 PM
Steve PH
Steve PH's Avatar
There's something missing, can't think what it could be !
Old 05-21-2005, 04:42 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
After Purple Power and 10 minutes with a pressure washer (thanx evil944t!):
Old 05-21-2005, 04:44 PM
PCA 944
PCA 944's Avatar
I don't think it worked. There is still no engine.
Old 05-21-2005, 04:45 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
Old 05-21-2005, 04:46 PM
The DareDevil
The DareDevil's Avatar
Nice job!!!!!
Old 05-21-2005, 04:47 PM
my84-944
my84-944's Avatar
HOLY COW. That purple stuff ate your engine. JK looks like it works, realy well.
Old 05-21-2005, 04:53 PM
TRWright
TRWright's Avatar
Amazing! Now I need to pull my engine just to clean things up!
Old 05-21-2005, 05:05 PM
Mike Murcia
Mike Murcia's Avatar
Looks great Michelle! I remember doing that, except it was about 5 degrees outside and I was in the garage with a bottle of simple green and an old toothbrush.
Are those motor mounts original?
Old 05-21-2005, 05:21 PM
Porsche-O-Phile
Porsche-O-Phile's Avatar
That's about half of a clutch job right there. . .
Old 05-21-2005, 05:57 PM
944_S_TYPE
944_S_TYPE's Avatar
Hey michelle, I am sure that you knew this already.....But That slave cylinder looks original There is no better time to do a master/slave install. Just install hook up the power bleeder and go!
Also, It looks like you did not cap the P/S lines You will probbaly need to purge the system to get the water out....Or it will leak (If it does not already)
Old 05-21-2005, 06:04 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
cleaning the engine bay?
Old 05-21-2005, 07:22 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
New clutch slave and master are sitting in the carriage house
Mike:
As far as I know they're original. The new ones (OEM) are sitting next to the clutch slave,
Old 05-21-2005, 08:09 PM
Porsche-O-Phile
No, all the labor to this point!
Old 05-21-2005, 08:20 PM
badcoupe
badcoupe's Avatar
did the exact same thing thursday with my pressure washer amazing what a 13hp honda does! I did my engine as well. I never knew it really was silver!
Quick Reply: Purple Power!!
