Best Paint remover
Location: The mistake on the lake other wise known as Erie PA
Best Paint remover
What is a good paint remover to use for prep before taking a panel to get painted by a body shop?
depends on how far down you want to go...i usually sand, but recently ive been using marhyde aircraft remover to take it off down to original coating of zinc-or in my case bare metal.
if you have original paint in decent condition, i wouldnt strip it. If it has been repainted or is real nasty, then stripping is the key. you are much better just wetsanding the car down and feathering out the knicks and spotting it in w/ some real eurethane primer.
I have been using airstrip aircraft stripper takes about 5-10 minutes depending on the temperature. I stripped my 944 in a day at about 80 degrees with help from my dad.
Yes the aircraft stripper will melt plastic it even tells you if you got it on your skin lol. I pretty much completely disassembed my car before doing any kind of strippig, and its actually called talstrip not airstrip as i stated before.
i went up to maryland to pick up my buddys new 300zx tt but on our way home we stopped in at a liquor store for some everclear... i hear that will clear up paint pretty well.... lol jk, it'll sure put hair on your chest though
