floor jack recommendations?
Hi all. I'm looking for recommendations for a low profile floor jack to use on my 951. My current one doesn't go under it, it's too tall. Any recommendations? It would be noce to find a lightweight aluminum one of they're not too pricey ..... Thanks again! This forum is the BEST!
Rennlist Lifetime Member
I'm very happy with my aluminum jack from Sears; reasonable weight, built very well and goes under my lowered 951S without a problem. They're about $199 normally but go on sale occassionally.
My favorite jacks are my AC Hydraulic jacks - they're awesome but about 2-3 times the price.
If you have a Sam's Club or Price Club (Costco) by you, they should carry an aluminum floor jack for about $100-150 (i cant remember). I was going to buy one of these while i worked at a Sam's club, but they we ran out of stock before i decided to buy it. They never got them back in until a month or so after i had moved from the area (and left the job).
Otherwise Sears as a really nice aluminum jack for $119. Its load limit is 1.5 tons and even has a magnetic parts tray!
I have been meaning to buy the Sears one, but havent had any jobs which required jacking the car up yet.
Thinking outside da' bun...
I got a Ranger jack. Pretty nice. A couple of the models are 5-10lb lighter than normal non-racing jacks. I had to have a red jack because Im a dweeb so it was one of the few.
http://www.asedeals.com/Ranger_floor_jacks.html
dude! my g/f got me a low profile jack for my b-day and its awsome. Its a full sized 2 ton jack from NAPA called a furious jack or something, very good quality, but the front of the jack is lowered down to like maybe 2-3" and fits right under a lowered car. Not as light as the aluminum jack but prob. better for lifting the car for any length of time. I beilieve it was around $200 though.
Administrator - "Tyson"
I was going to buy the Harbor Freight jack until a friend of mine broke his - the jack pad plate craked down the middle and broke off. I did some searching around the web - not uncommon. Few sites stated the problem was fixed.
I have the HF jack as well. Its light and nice to drag around to change tires with at the track / autox but I wouldn't trust it for every day use. It creaks and cracks a lot, plus it doesn't lift the car high enough when I want to block up the wheels to do alignment adjustments.
But, it does fit under the car nicely, with about 2" between the jack pad and the car.
