Smooth shifting
Smooth shifting
Hey there, put in a short shifter about 8 months ago, which gave a short shift but not VERY smooth. I put some silicon (I know the speeling is off), on the joins right under the boot, all I can say is WOW!! It made shifting VERY much smoother!! I would say ANYONE, with or without the short shifter to spray some on the ball joint at the bottom and also the middle part where it connects. It won't hurt.
Originally Posted by AndyK
That wont attract extra dirt on the vital parts, will it?
I would do it if I were you, it is simple. You have to get the boot up, not out, be sure to use a screw driver or something to slide down the side. Put the boot up easy then it should pop. Then there is the rubber boot under that which taking off is easy but getting on can be a pain to make sure it is all the way on. After that, you should see the two joints, at the bottom and the middle. Spray some on them and then shift some, spray some more. After I started to drive my car some, I COULDN'T believe the difference! It was like a BMW tranmission, nice and smooth.
UAE Rennlist Ambassador
I did that, helped improve shifting but not so much.
You could get the early 924 bushings that go where the shift leverl mounts into the rod. Apparently only the 924's came with bushings while other models didn't (?)
I ordered some though should be here soon.........
