My rear wiper is called "Twitch"...
Old 10-27-2004, 07:23 PM
Bryan Welch
Bryan Welch's Avatar
Default My rear wiper is called "Twitch"...
because whenever I try to use the wiper, it simply moves an inch and then moves back to where it started, over and over. Turning off the wiper doesn't make it stop. In fact, it won't stop until you manually move the wiper all the way down to where it should go and then back up.
This is on a 1991 944S2 Coupe. Any ideas what might be wrong?
thanks,
Bryan
Old 10-28-2004, 02:12 AM
DanB944T
5th Gear
DanB944T's Avatar
I think you'll find that a gear has stripped in the motor/assembly. Something similar happend with mine many years ago... evidently the seal where the shaft goes thru the glass was bad and water got into the assembly and ruined the gear over time.
Old 10-28-2004, 02:24 AM
Zero10
Zero10's Avatar
Sounds like when the nut on the top of mine came loose.
Except it would usually twich right off the side of the hatch.
It's either the gear, or the nut =)
Old 10-28-2004, 02:26 AM
Travis - sflraver
Travis - sflraver's Avatar
You use the wiper back there?
Old 10-28-2004, 12:41 PM
Don 944 LA
Don 944 LA's Avatar
What wiper ..... ?
I lost mine aloooong time ago... looks better
get ya some Rain-X and all is fine...
Old 10-28-2004, 03:39 PM
Bryan Welch
How did you fill the hole where the bolt through the glass went?
Old 10-28-2004, 03:52 PM
Travis - sflraver
They make a plug for it. It has a porsche part number I believe. Check with paragon/944online/ etc..
Old 10-28-2004, 04:38 PM
RMills944
RMills944's Avatar
Someone on the board a while back was selling plugs that were nice aluminum and you could get it powdercoated in black - I don't remember who it was, but I'd like one too since my car doesn't even see rain!
Old 10-29-2004, 10:36 AM
RMills944
RMills944's Avatar
someone has to know where to buy those plugs...
Old 10-29-2004, 10:48 AM
sm
sm's Avatar
http://www.arnnworx.com/
scroll to bottom of page...
Old 10-29-2004, 12:46 PM
silverBean
silverBean's Avatar
My wiper just went out. And its just getting cold enough to where i have a fair amount of condinsation in the am. It worked fine before,just went to turn it on and nothing. Any ideas?
Old 10-29-2004, 09:19 PM
Scuba Steve
Scuba Steve's Avatar
How much does a wiper motor assembly normally go for?
Quick Reply: My rear wiper is called "Twitch"...
