clutch sticks to the floor
Its happened a couple times to me before. The clutch would stick close to the floor and I was able to just pull it up with my foot. Now it seems to be on the floor and almost no room for me to stick my foot underneath and pull it up. I have to know literally get out of the car and reach for the pedal and pull it back and it springs back to place. Is the somewhere where I have to lube or grease up on the pedal for this to not happen. Thanks in advance.
You have either air somewhere in the like down to the clutch slave cylinder, or a leaking clutch slave cylinder.
If the slave cylinder is leaking, it's just a matter of time before it totally fails, then you can't put the clutch in. Remove the clutch inspection hole plug and see if there's any brake fluid inside (there shouldn't be).
Slave Cylinder is not functioning. Recommend replace slave and master, once you have tried bleeding the system.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
As far as air in the system would the rubber grommet missing cause these problems. The ididots at jiffy lube lost it I wonder if that why I'm having these probs. So definately not the pedal itself that needs lubing.
Wax On, Wax Off
Yeah...there's a leak in the system...as for the rubber grommet, I have no clue what you're talking about...
and what the hell are you doing taking a Porsche to jiffy lube?
Monkeys Removed by Request
Why in the hell are you taking your car to a jiffy lube. Those guys are idiot's. Do your own oil and lube changes trust me...less hassle in the end.
