Probably the most pissed of Man of earth
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
I took the car for the drive to hear some of the rattles and next u know i have coolant on my window. I drive home look under the hood and it looked like the coolant sprayed every where. I check the coolant tank and now it is empty. I stick my finger in the coolant tank and i get some milky stuff out
Sorry about your bad luck, Daniel. You definitely are one angry man if you stooped to the level of calling your 951 a POS... Mine probably has a spun rod bearing, but, then again, it is an 18 year old car, with many miles, and I just have to accept my bad luck, even though I don't like it one bit. I know it is hard to love her when a 2-3K dollar looms, but I hope you won't part with her. Good luck with everything!
Going with the pack
is quite monotonous.
NPS - which one?
Daniel -![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
do a compression test
hopefully just the oil cooler seals (although I have no idea how coolant would be spraying everywhere)...
was it running hot?
Daniel -
was it running hot?
the thing that pisses me off so much is i just got done taking that whole dam engine out and fixing all the seals. I did balance shafts,slave cylinder,oil pump gasket, ran all new electrical wires and upgraded them, 24kt gold battery connectors,new cup clutch,all new bolts in cv joints,pressure plate bolts, new turbo, new chips,new oil pan gasket, new exhaust,reliaboost,valves, valves guides, All head work was done, New head gasket, New front seal, new exhaust, New rims and tires, new turbo water pump,shifter,had a new windshield done within 2 years, and the list goes on and on. I have done all of this work within the last year and out of that year i drove the car maybe 3 months. I can't take putting any more work or money into this car. If i fix these problems the car will still be for sale and even if i don't it will still be for sale.. If anyone is intersted contact me.
Originally Posted by mnmblu
Dump it and get a 993. No coolant to worry about. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Alan, most of these guys would buy a 993 in a second, if they could afford it. Of course to some, its not their cup of tea. remember, most of us are either not that wealty, or still young, and not working on their career yet, the latter being my situation.
Alan and I swaped rock chips this sunday morning following eachother, it was a good time! (except the rock chips, I feel like a criminal doing that to your beautiful blue paint!)
~Eyal
Wax On, Wax Off
Daniel, the only way I think it could show on the window is if the heater core hoses blew. check those out too...if one was disconnected, I can see it spraying everywhere....
Just a thought....
Just a thought....
