Hesitation problem again!
#46
Never died for me. If you already verified the correct gap, then I'd say that wasn't it, although it certainly didn't hurt to fix.
Have you checked/replaced your DME recently?
#48
I Murdered Hitler: the A/F mixture is fine and it passes emissions fine. The mixture jumps all the way lean every few seconds, but just for a split second.
The car, when just started, will almost stall if you hit the gas within about 20 seconds of starting it. If you wait a minute, then drive, it's fine. I'm going to clean the injectors, get new plugs, and a new AFM if necessary. After that, then exhaust tubes and cat need replaced. Hopefully that will fix the problem somewhere in there.
#49
Wax On, Wax Off
Originally Posted by i murdered hitler
i've been reading most of everything on this board for the past 3 months and i made a membership a few weeks ago.
i've got 3 944's in the driveway, all n/a. the '86 is going to be a parts car pretty soon, not much of it is worth putting in another car. the drivers rear quarter is wiped out. i looked for a replacement and i found an '87 with 175,000 mi. that needed a clutch. paid $400 and towed it the entire 3 blocks to my house.
i'm currently going to a tech. school taking auto technology and i graduate in 6 months. i wanted to go to school because i had a hard time diagnosing my old bmw every time it quit on me. i was great at pulling heads and starters, but i didnt know why my engine blew a head gasket just because of a little pinging. i wanted to be a porsche tech but i decided that there aren't enough porsche dealerships around and if i wanted to move, i couldn't.
sorry if i came off as a jerk telling everyone to take their cars to someone who will only charge them too much money for diagnosis; just think of this, $30 and some research on exhaust gasses and you could find out precisely whats going on in your combustion chamber. i'm just giving out my knowledge to save some money.
#51
#52
Hey people. I just bought a 86 944 na, found a ton of great stuff here at rennlist for a few repairs I had to make (man. trans coupling, sunroof, other misc. things), thanks! I didn't read any posts that mentioned the fuel *pump*, so I thought I'd throw that out there. A friend of mine owns a 94 Ford Explorer, and had problems that were very similar to those described, b/c of the bad pump...I know, its a Ford, and I also don't know too horribly much about the 944 or fuel injection technology, but it seems like there's still alot of head scratching going on, so I thought it couldn't hurt to mention it! Hope you guys can get your cars back out on the street.
Trevor
Trevor
