944 mk1 - unidentified disconnected cables
Hi everyone,
I've found these disconnected cables near the firewall on the driver side of my '85 mk1 944; could anyone help me identify what they were supposed to be connected and why they might have been left this way?
driver side firewall - engine side
driver side firewall - engine side (2)
driver side firewall - cabin side
Thanks!
Thanks!
They aren't connected to anything in any car I've seen. When I had my harness out I found the other end of some of them, they didn't go anywhere so I eliminated them. I've heard speculation on what they could've been for but I don't recall what the general consensus was.
Tiger03447 (09-04-2024)
944 Mk1
The hood light is connected to the inside of the hood. The light has a pigtail on it to plug into the rectangular connector. The light has a mercury switch that connects the circuitry when you raise the hood.😀
interesting! Thanks! I have to search for this then... Does anyone has a picture of where this light is supposed to be?
M1-944 wiring
OK.. the red wire with the black tracer goes to one side of the high pressure switch located on the receiver dryer near the L front headlight. There should be similar wire with a rubber boot that hooks to the existing wire. If you do not have A/C in the car, just ignore the wire. I will try again to post a couple of pics of the under hood light as well as the red wire connection.
Under hood light connection
Under hood light..less bulb
en_ky (09-07-2024)
Thanks very much for all the replies!
ok so.. my car does not comes with AC so that black wire engine side should actually be useless in my case if I understood correctly.
About the one that should connect the hood light. I found the bulb housing (was wandering why there was that socket there) but the cable that comes out from that goes to the left inside the hood where it is connected to another cable with a white, wide rectangular connector. I'm not able to find the single cable that should comes down and connect to the green/yellow "blank"...
Tiger03447 (09-11-2024)
Unidentified wire and connector
Gents: after looking at my car, and consulting the schematic, the yellow and grey wire goes into the pictured T-1 connector. It comes out of the connector as a black wire, going to the engine bay hood light. Just an update.😀
