Sway bar size?
Sway bar size?
Could anyone tell me what size the front sway bar is on a stock 85.5 NA?
Have mine torn apart and the new inners are the wrong diameter (too large) and the outers are the wrong shape to fit...
OE is 20mm - it's likely that you got 23mm as that was the other popular optional swaybar. The ends should be round - if they have a flat side, then you got the ones for an early steel arm car (83-85.1).
It's a great idea to actually measure the sway bars before ordering parts - unless you are the original owner, not telling what combination you may have.
Good Luck!
Good Luck!
They should be able to fit ones from an 86 on an early car..ERAU944 put my S2's old stock sway bars on his 84 with no problems besides needing bigger drop links because of the diameter difference.
thats righto!
and before that i had an '87 944 front swaybar on in the old drop links... i just used the bushings from that bar when i put it on, and the ends from the old bar. the S2 outers needed a little bit bigger outer bushing, but you can hone out the bushings a bit and it'll go right in.
-Mike-
-Mike-
Originally posted by zehnd
Skip are you saying that an 86 OEM front sway bar won't fit on an early car.
