Oil psi needle jumps up and down?
My oil psi needle on the gauge starts to jump up and down when the car gets warm. I suppose it is the sender unit!?
Is it hard to change? Is it expensive?
951-89
Dave
951-89
Dave
It is most likely the sender. It should run around $50 to $60. It's a simple job. Disconnect 2 wires, unscrew the old one and screw in a new one. It's just below the oil filter.
Hi Dave,
I have the same "problem" with my gauge. Please let me know if and how you fix the problem. I've had the car for over 2 years and it's been like that since day 1.
Thanks...
Thanks...
1 Post
I'm not sure if a new sender unit will cure it completely. I put a new one (item from a dealer), and the needle occasionally vibrates at idle (on not-hot engine, with the pressure around 4 units).
There is a small hole in the sender body through which oil gets to the sender. If there is an air bubble trapped in, maybe this is the problem? But I don't know how to purge air out of it (there is no bleeding hole).
On my 85.5 944 the needle bounced around like a VU meter. A new sender cured it.
It may also be a good idea to pull the OPRV and clean it real good while you're there.
Originally posted by fokker
Where is the OPRV and what does it do?
All the info is there.
