New brake calipers
Need to do front brake job on 1987 924s. Including rebuild or replace calipers. Having trouble finding calipers so I can price them relative to rebuild. Googled around but nothing popped up. Anybody point me in right direction? Thank you.
Rainman
Try calling the local warehouse store for Autozone/Oreilly - they can order rebuilt 944 calipers for around $55/apiece.
Or you can go with these guys - pricey but great reputation.
https://www.pmbperformance.com/other-brakes.html
If you need any cores to exchange I have a spare pair of front calipers I'd sell cheap.
The sliding grooves in the stationary part where corroded as was the slider tongue. The alignment spring were bent as compared to a new spring. The brake pad retaining pins were corroded.
The front pads were not releasing from the rotor and one pad was 50% less remaining thickness compared to it's mate. When I came to a slow rolling stop with the car, the car stop without depressing the brake pedal.
I completely rebuilt and cleaned all deposits in the tongue and groove, replaced all worn parts. I would say the special deal of $350 is a deal. It took me about 3 hours per caliper to return to as new condition
Rainman
The 924S and early 944 brake systems are identical - every single part is carried over.
