No Start Problem
Old 05-11-2022, 08:36 PM
  #271
Acantor
Acantor's Avatar
Originally Posted by orig944
PET calls for the same all years for US. I would double check the markings on each before swapping. If Pat drives his 944 over and his works in your car, make sure yours does not work in his car to confirm. In fact, maybe do this first instead of risking his ECU in your car.
ok that sounds like it will be a safe option.
Old 05-11-2022, 08:55 PM
  #272
T&T Racing
T&T Racing's Avatar
Originally Posted by Acantor
I just talked to Pat and he said that he has an early 85 that works, and he said that we could switch the DMEs to test. Would this work eventhough they are different years (I know there are suttle changes from each year of the early models)
An early 85 DME is compatible with a 83-84 DME. The 85.5+ thru late had a 5V signal for AFM, so you then need to have 85.5+ AFM with 85.5+ DME. Check Clarks Garage
Old 05-11-2022, 08:57 PM
  #273
Acantor
Acantor's Avatar
ok so I will put everything on pause for now till we can see if my DME works in his car.
harveyf (05-11-2022)
Old 05-12-2022, 12:48 AM
  #274
Legoland951
Legoland951's Avatar
If the DME works with starting fluid, it works for gas.
I wouldn't be looking at the DME right now.
You have to see if larger amount of starting fluid and more throttle will make the motor rev up higher.
If this is the case, you are not getting enough fuel.
The steps are systematic. Right now you are playing the guessing game and doing trial and error with the DME.
It doesn't rule out the DME but the starting fluid test takes a few minutes will narrow down the problem significantly.
Old 05-12-2022, 09:05 AM
  #275
Acantor
Acantor's Avatar
I have already done this test and it does run.
  #276
T&T Racing
T&T Racing's Avatar
I AGREE
Old 05-12-2022, 09:06 AM
  #277
Acantor
Acantor's Avatar
I AGREE
we already know it runs with starting fluid
Old 05-12-2022, 09:12 AM
  #278
T&T Racing
T&T Racing's Avatar
Then proceed with obtaining the spare ECU for testing.
I support your assessment. Let's try the spare ECU
Old 05-12-2022, 09:16 AM
  #279
Acantor
Acantor's Avatar
haha alright
Old 05-12-2022, 11:15 AM
  #280
harveyf
harveyf's Avatar
It sounds like you have a line on a spare ECU.
Altough I cannot personally volunteer, since I don't have a 944 at the moment, there is a world where you put your ECU in a flat rate box and send it to one of the folks participating in this thread. They can plug your ECU into their car and see what happens. As far as I know, there is zero risk that a bad ECU can do damage, especially if it doesn't allow the car to even start. I'm sure if you ask, someone will support you in this effort.
Old 05-12-2022, 11:37 AM
  #281
Acantor
Acantor's Avatar
Pat is driving his 944 to my house and we will swap it this weekend
Old 05-12-2022, 01:45 PM
  #282
Legoland951
You know it runs. How does it run under throttle with increased amount of starting fluid? Does it rev up like normal or not?
While it is being revved up with starting fluid, do you know what the injectors are doing in terms with injection pulse frequency via the noid light as do they all increase in frequency with increased RPM as they should?
Also, do the injectors actually open and close spraying into a cup with higher frequency in correspondence to the injector pulse? Also, do they spray corresponding amount of fuel into the cups as the RPM increases with more throttle/starting fluid?
Old 05-12-2022, 01:53 PM
  #283
Acantor
Acantor's Avatar
I did not test throttle with starting fluid, but it ran with the temp sensor unplugged and I reved it and everything was normal.
Old 05-12-2022, 02:02 PM
  #284
Legoland951
Does it run normally all the time with the temp sensor disconnected? Idle smoothly and drive with power?
Old 05-12-2022, 09:20 PM
  #285
Acantor
Acantor's Avatar
I haven't driven it, but I have run it and reved it and it was smooth. I does not run everytime with the temp sensor disconnected.
Quick Reply: No Start Problem
