Do You Have To Bleed The Slave?
Just changed out the master clutch cylinder and bleed all 4-brakes and master cylinder and now a have the dreaded clutch to the floor. Looked thru past post and didnt see if i have to bleed the slave cyl. also. I was really not looking forward to doing it this weekend, but was rather going to replace it in a couple weeks. Any thoughts! I was using a motive bleeder when bleeding. Help, thanks! Scott.
Don't bleed it. Replace it (and the hose between the master and slave too). If you had to change the clutch master then the slave will most likely fail very shortly, if it hasn't already.
If you decide to keep the old slave then yes, you do have to bleed it. The clutch is on the floor because air is stuck in the line between clutch and slave or in the slave itself.
Bleed the slave, not hard at all with the Motive Bleeder, be sure and remove the ground from the battery, wrenches around the starter is not pretty and it is best to replace the slave and master at the same time.
Im going to soung stupid here I know but nothing new. Whats the nipple at back of slave, dosent have anything attached to it. Do you have to pull the starter just to bleed the slave. Thanks, Scott.
Okay, a question I was tossing around, answered! Thanks!
- Julie
- Julie
I just did this tonite with the motive power bleeder. Took me about 20 minutes from jacking the car up to dropping it back down while changing out and putting in all new ATE Super Blue. Needs a 7mm wrench, I put my motive hose on the nipple and just opened it enough to bleed out and it worked great. In fact I was able to just hold the wrench on it while bleeding and tight it back up so it wouldn't run out anymore very easily.
Of course as Matt said, I have girl hands so it wasn't too hard for me to reach but it took a couple of minutes to get the bleed hose attached to the nipple.
Good luck!
Good luck!
