944S head cracked
Old 02-23-2004, 02:45 AM
wwboater
wwboater's Avatar
Default 944S head cracked
Just finished putting on the head to a 944S and the head cracked after running for about 45 - 90 sec. Had good oil pressure. Had water in the car. I do not know why it cracked. It cracked between # 2 and 3 cylenders. The crack goes from above and to the right of #3 exhaust outlet almost to the top of the head.
So now do I find a 16v head or just put an 8v head on it. What is involved with putting a 8v head on it? Any one have a cheap 16v head (Albert)?
Craig
Old 02-23-2004, 03:08 AM
jonnybgood
jonnybgood's Avatar
Bummer. can you post pics?
Good 16v heads are not cheap. There was a 944S complete engine in Rennlist classified for $1500. Of course swapping engines is much more work. You could take the head off that one...
You should find out why that one cracked before you put another head on it. Can't be due to overheating after only 90sec.
Old 02-23-2004, 03:44 AM
Jonas Goldsmith
Jonas Goldsmith's Avatar
Default Re: 944S head cracked
Craig
Good luck finding a head... After mine was ****ed up by an auto mechanic i used to go to, i figured this to be an option... but u just can't find them... and if you do... its a huge pain in the *** to rebuild it and then put that one back on (as you know...) Basically you have a 1000-2000 dollar paperweight now...
Sorry about what happened, but i am in the same boat as you... I feel your pain...
Cheers,
Jonas
Old 02-23-2004, 03:50 AM
J Chen
J Chen's Avatar
Hi wwboater,
Please check your PM
Old 02-23-2004, 08:24 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,168 Likes on 1,225 Posts
To add insult to injury, check out the 951 thread. A bunch of 951 owners are buying 944S heads for their boosted cars. These heads are going to be impossible to find in a few years.
Old 02-23-2004, 09:35 AM
wwboater
wwboater's Avatar
Yes I need to find out why it cracked. I also do not think that it overheated that fast.
Have any of you guys put an 8v on a 16 v car?
Old 02-23-2004, 01:14 PM
SoCal Driver
SoCal Driver's Avatar
Default Re: Re: 944S head cracked
Originally posted by Jonas Goldsmith
Good luck finding a head... After mine was ****ed up by an auto mechanic i used to go to...
Cheers,
Jonas
Used to go too? Anderson I suspect?
Old 02-23-2004, 01:22 PM
Dave
Dave's Avatar
That was my guess!
Old 02-23-2004, 01:28 PM
Zero10
Zero10's Avatar
The 8v will -fit- on a 16v block, but you would be changing all your manifolds, and probably a few other parts on the way, along with whatever you would have to change in the head.
I know 944online sells rebuilt heads, including the 16v, it may be a little steep because you don't have a core anymore.
I have seen stripped heads going for 500-700, but that was on e-bay a little while ago.
Old 02-23-2004, 01:33 PM
hacker-pschorr
I'll sell you the one from my car for about $5k:
New Cams (less than 2k on them)
New valve guides (see above)
Valve job done with the above
new tensioner & chain
There's one catch, you have to take the rest of the engine (thrown rod bearing) and body (recent 951 brake upgrade) with it.
Old 02-23-2004, 03:25 PM
Jonas Goldsmith
Default Re: Re: Re: 944S head cracked
SoCal, you will see a post soon.... then u will know... (yes, anderson, wait for the post for further details...)
Old 02-23-2004, 04:48 PM
Robert D
Robert D's Avatar
Haha, you could also take my '88 Stone Grey 944S for ~7k.
Old 02-23-2004, 04:52 PM
exc911ence
exc911ence's Avatar
Will an S2/968 head fit a 944S block?
Old 02-23-2004, 04:56 PM
hacker-pschorr
Getting the car to move under the power of a pair of hampsters would be easier.
In other words, not without a LOT of screwing around.
Old 02-23-2004, 05:06 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
would a 928 S4 head fit? I don't think they are all that different...
Andy
Quick Reply: 944S head cracked
