Oil pressure readings
Hi, I would like to know what you get from your oil pressure gauge. I have a '86 944 NA, and even though I looked everywhere on the Web, it is still unclear what the standard reading should be. I use Mobil 1 0w40, and here in Montréal Canada the weather is between 15C and 30C. My gauge shows 5 bars when cold, and when hot its bounces between 3 and 4 on idle. Stays at 5 when driving. Is that normal? Excuse my so-so english...
I'd recommend 20W-50, but I started swapping to 10W-40 for the "dead of winter" months to help with oil pressure on startup. Your oil pressure seems fine, mine always runs at 5 when driving and at idle between 3 and 4 is fine as well. Porsche does recommend 20W-50, BUT everyone has an opinion about what weight to run in the 944, so take my opinion with a grain of salt. Regardless, your oil pressure is ok, so I wouldn't worry about it all.
I'm confused about the oil.... Last year I called the nearest Porsche dealer to ask about it and he said they recommand 0W40....So many different answers everywhere!
Maybe the guy didnt know whats hes talking about. Porsche manual says also w50.
Anyway many use w40 oil and have no problems. I used 5w40 all season and now i have new sleeves in the block but i dont think oil was the only culprit, still will go w50 oil from now on.
Agree you oil pressure numbers seem fine. FWIW the shop manual specifies 4 bar at 3-4000 rpm. I would assume that is on a fully warmed up engine.
Anyway, I run 10w60 to keep my 170+ miles engine above 2 bar at idle. It does hit 4 bar at higher rpm so I guess I'm still in spec. Pulls strong.. gets reasonable mileage.. carry on...
