Really Hot Engine Bay
Old 02-24-2004, 09:45 PM
shortyboy
shortyboy's Avatar
hmm,i can also smell smoke in the cabin of my car and i get dizzy sometimes(not that dizzy tho)so it could also be rear main oil seal.also,when at idle and the temp rises,i raise the rev 2k and the temp goes down slowly.thanx
Old 02-24-2004, 10:24 PM
JDeitz951
Lifetime Member
JDeitz951's Avatar
That near-overheating is a bad problem and will screw you if you don't fix it. Headgasket leaks don't cause overheating until the coolant level gets too low. You have a cooling system problem. How's the water pump? Belt tension? No leaks? If you have a head gasket leak into the cooling system, it will pressurize the resevoir and make bubbles or overflow after you shut down. Have you noticed this?
Old 02-25-2004, 01:10 AM
Porsche-O-Phile
Porsche-O-Phile's Avatar
Yah, I wouldn't run the car too much if there's excess heat - particularly localized in one area and not another (stress) they're aluminum after all. . .
Old 02-25-2004, 04:16 AM
shortyboy
shortyboy's Avatar
i dont know if my belt is at the right tension.can i do this myself?my coolant overflowed once,that was due to when i was stuck in trafic and i had my a/c on.would a rear main seal cause my car to get hot or would it only cause leaks.thanx again
Old 02-26-2004, 06:52 PM
Cyrus951
Cyrus951's Avatar
holy ****, im getting the same heat on the passenger side (around headgasket), and I also get that ****ty smell inside the cabin that makes me dizzy. more info please!!
Old 03-03-2004, 06:36 PM
Cyrus951
Cyrus951's Avatar
bump
Old 03-03-2004, 06:40 PM
Campeck
Campeck Rulez
Campeck's Avatar
Originally posted by Paul T.
Three words: JET HOT COATINGS
yup.
if you get it coated there is a significant drop in heat.
we can run my dads car for like 2 min and touch the pipe right away!
Old 03-03-2004, 10:16 PM
cruise98
cruise98's Avatar
If you still have the catalytic converter, it could be clogged and causing this problem as well.
Old 03-04-2004, 08:20 AM
Kevin Baker
Kevin Baker's Avatar
Keith, exactly correct, gold star and go to the head of the class.
Your cat is dying, dont call the vet, you need to get to an exhaust shop. A significant heat increase on the pass side is from the exhaust gasses that are not getting out quickly enough. You probably also have LOTS of heat in the little bin under the radio. Right? Ask me how I know? BTW you will also have to replace the little gaskets from the headers to the down pipe. And then a few months later you will realize that there is STILL a small exhaust leak somewhere.
Also, when you think you are done, go ahead and replace the DME engine temp sender because it is shot and it is the root cause of your cat becoming clogged. It has been giving the DME an incorrect engine temp and causing the engine to run rich (which clogged your cat).
Old 03-04-2004, 10:38 PM
shortyboy
shortyboy's Avatar
that would be the case if i had a cat!hahahathe PO cut it out and put a pipe in.thanx tho,still havent found the problem,still looking.
Old 03-04-2004, 10:39 PM
shortyboy
shortyboy's Avatar
Old 03-04-2004, 11:23 PM
Kevin Baker
If you don't have a cat. (You cat killer, I'm calling PETA) The dme engine temp sender could still be the cause of your increased combustion/exhaust temperatures. Note: The car will run with this thing acting wiggy.
FI problems usually cause the cat to go bad=get rid of cat. Now you are still faced with underlying FI (Fuel Injection) problem. Think, what happens when the car is trying to "warm up" as in cold start. Full lean mix to increase combustion temp to warm up the engine.
Old 03-05-2004, 03:28 AM
shortyboy
shortyboy's Avatar
im also strating to also think it might be my spark plugs(ive heard you have to go colder range if your car is modded)
Old 03-05-2004, 07:57 AM
Kevin Baker
OK, but you STILL have to find the CAUSE of the increased exhaust temp. This issue is totaly unrelated to coolant temp. Which you should also be worried about why that happened. BTW which, of your several, is this problem with?
Old 03-28-2004, 12:36 PM
Cyrus951
Cyrus951's Avatar
bump
Quick Reply: Really Hot Engine Bay
