Cone Filter vs. Stock Intake on 944s
Ok so I searched through past topics but i couldn't find exactly what i am looking for. I wanted to know if anyone has any information on the advantages/disadvantages of going to a K&N cone filter intake vs. the stock 944s intake. any information would be appreciated.
Advantages: More engine noise, weight reduction due to lighter wallet
I don't think just sticking a cone filter in the stock filter location will make any difference, as you're just sucking in hot engine-bay air. If you re-routed it to be like an S2, though (in the nose panel), you might see a *slight* gain. But don't expect anything even noticible either way.
Throwing a K&N flat-panel filter in the stock airbox will help it breath a little better.
One of the major problems I see with the cone filters out there is the adapter. They disturb the air flow into the AFM when they should be smoothing it. 9X Auto and Broadfoot racing have both come out with improved adapters, but IMHO they are still not as good as they should be.
Ideally what you want is a cold air intake. What passes in the Porsche community for a CAI is not worth talking about. What generates power with a CAI is not so much the cold air, but the length of the pipe. In fact, AEM designs their CAIs through dyno testing. They create an adapter for whatever airflow meter, attach a length of pipe with a filter on the end and dyno it. Then they remove 1/2" and redyno and repeat. They determine which length makes the most power than that's the length they put into production.
What I would do (short of getting a custom-made adapter) is to get the 9X kit and create a CAI by attaching a custom-made pipe that places the filter in the stock air pick-up location. What would be even better is to create a new pipe to replace the piece between the AFM and the TB. I am not able to do this per the SCCA IT rules, but I will be making a CAI and having my machinist make a better adapter that really smooths the airflow.
But you are right, the flow of the air is much more important than the actual "cold air." I'll bet most aftermarket systems out there don't have any CFD done on them. Who cares if the air is 20* cooler, if you aren't optimizing the flow all the way up to the engine?
On the NA cars, the air-temp really is a factor. Putting a K&N in the engine-compartment will typically pick up air that's 30-40 degrees warmer than outside ambient temperatures. Every 10-degree difference is worth 1% in power, so you've just lost 3-4%. Then the actual increase in flow would be minimal because the major restriction is the AFM, not the air-cleaner. It's like trying to drink faster through a straw by using a bigger cup, not gonna make a whole lot of difference.
The NA cars are much, much tougher to extract extra power from. The most you can hope for is a VE=1, perhaps a little percentage more in some RPM-ranges. On a turbo car, you can make up for that increased air-temperature by just turning up the boost. So VE=1 is a piece of cake and you can get VE=2-3 for a 200-300% increase in power over an NA easily. That little 3-4% loss from higher air-temps won't even dent the increased flow of a turbo, but on an NA, you'll end up taking a loss on that K&N filter.
BTW, you can get greater than 100% VE. Just not with a road car. F1 and Moto GP engines have VEs greater than 100%. Not much greater, but they are greater. Amazing what you can do with millions of dollars.
....but on an NA, you'll end up taking a loss on that K&N filter.
adfsouth (03-29-2020)
Originally posted by iloveporsches
You know, they make programs that can calculate all of this.
Originally posted by Geo
Moot point. Almost all NA cars have "sucking losses." A good CAI with a well tuned pipe will increase VE.
mmm F1
-Michael-
Originally posted by Blue S2
So why did Porsche not put the air filter in the nose panel like on the S2 on all the N/A cars?
Yeah, forgot about that. The factory already gave us a CAI, since it sucks in air from an area isolated from the engine's heat. I'd say just go with the flat K&N filter if anything. They do make good filters, there's just too much BS out there about CAI's giving people 10hp and stuff like that.
Here are several recent posts on the topic, this has been covered many times. Some people say K&Ns flow "more" air, tell me how much.
If you really want to buy one, that's fine, but don't try to convince me there's a power improvement unless you have the facts to back it up.
It's like all the bike guys who buy loud performance exhausts and don't realize they're getting less power, not more
https://rennlist.com/forums/showthre...er+better+cone
If you guys want to laugh for days, check out the VW boards and just type in CAI. Its the never ending argument. Its really rediculous. For Mk4 Jetta/Golf the debate about a CAI vs. Short ram vs. stock box is outta control. It got me wondering the other night as i read through some of it.
I have seen sooo many 944s with a cone air filter next to the engine. Basically a "short-ram" as it is considered. I assume at least the 944 Turbos run hotter than my VW. (even my S2 feels hotter after normal driving) I figured how much worse could it be on my VW and i have added a short ram cone to mine.
A lot of people talk about "heat soak" on the VW engines from a cone next to the engine. Is this an issue on our 944s ??? Ive never even heard about this.
I have yet to dyno either of my cars, but i plan on it this spring.
The BS is in what people attribute the gains to and then do a crappy job in making one themselves. A cone filter blocked off under hood will make almost no hp. BTW, at speed, the air temp at the filter is damned near ambient. I know of three people who have done instrumented testing that has confirmed this.
CAIs work if they are designed right and use a tuned length of pipe.
