New 944 owner, right into the deep end
#136
But is there a way to know/check if an engine is original to the car? Or does it just come down to the SN of the engine matching the year of the vehicle to consider it "matching"?
#137
944 Chassis numbers
All 944 chassis numbers consist of two groups of code letters followed by the vehicle serial No.
Example WPO ZZZ 94 Z D N 4 00001-49999
WPO ZZZ = Europe RoW WPO AAO = USA/Canada
94 = first two digits of model No. standard 944 95 = first two digits of model No. 944 Turbo (951)
Z = Europe RoW O = USA/Canada
D= model year (1983); E=1984 up to 1990 L (later ZL) 1991 ZM, 1992 ZN
N = Neckarsulm (build plant)
4 = last digit of model No. (944) 1 = last digit of model No. (951)
followed by vehicle serial no.
944 Engine Numbers
1983 41D 0001-4999
41D 5001-9999
43D 0001-4999
43D 5001-9999
Serial numbers included expander numbers
A000-A999, B000-B999 and so on to H. 944 Europe RoW manual
944 Europe RoW auto
944 USA, Japan manual
944 USA, Japan auto
1984 41E 00001-20000
41E 20001-30000
43E 00001-20000
43E 20001-30000 944 Europe RoW manual
944 Europe RoW auto
944 USA, Japan, Canada manual
944 USA, Japan, Canada auto
1985 as for 1984; year code = F
serial no. expanded to 60000
1986 41G 00001-20000
41G 20001-30000
43G 00001-60000
43G 60001-90000
44G 0001-00320
45G 0001-20000 944 Europe RoW manual
944 Europe RoW auto
944 USA, Canada, Japan, Australia manual
944 USA, Canada, Japan, Australia auto
944 Turbo Europe RoW
944 Turbo Worldwide
1987 944: as for 1986 with model year code = H
45H 00001-10000
42H 00001-60000
944 turbo All markets
944S All markets
1988 46J 00001-60000
46J 60001-70000
42J 00001-50000
45J 00001-10000 944 Worldwide manual
944 Worldwide auto
944S Worldwide
944 Turbo, Worldwide
#140
#141
#142
What is the difference between VIN number and Chassis number?
I am having a hard time following the engine number info.
Here is our car's #'s
VIN: WP0AB94XHN473***
Engine: M44/07 43H07571
#143
Your numbers point to one of the 8246 944’s produced for the US market in 1987, the engine is also a 1987 number so is most likely original to the car.
#145
What sort of numbers should I be seeing on a compression test on this '87 944? Hoping to do a test in the next few days before I pull and decide what to do with the much lower miles but unknown motor currently sitting in Franky.
#147
#148
We noticed a couple things and I wanted to ask, in case it is due to something a PO did to the car. Hopefully some of you can she light if these are normal and intentional design features, or not working properly.
Horn does not work unless car is "on" meaning key in and in turned on.
The window switch on drivers door that works the passenger window is opposite. push up to go down, down to go up?
The drivers door cannot be locked by hand pushing the lock down. Passenger door can be locked/unlocked manually but not drivers, requires key in door.
