85/1 944 - Random wires, not sure where they belong?
Not sure where the wire goes as it's been awhile since I've been under the hood of an early car but the black and blue thing connects to a nipple on the back of a vacuum check valve on the brake booster. The nipple it connects to is still in the hose. A common thing to break. Not cheap to fix though (about $50 new).
Correct.
Correct, again.
That check valve is ~$45 and the grommet is ~$5.
If not mistaken, that non-functioning check valve supplies vacuum for the HVAC system. Does the heat in your car work, and can you currently re-direct airflow from the windshield to the foot wells?
Correct.
Correct, again.
Correct, again.
Either that or it's the heating for the windscreen wiper nozzles. Mine has always been like that and have been wondering for years now.
It is the wire that powers the hood lamp:
Wire runs from connector, under and along the wiper motor cover, secured via clips.
Up to the hood and secured by more clips...
And finally to the lamp socket...
