Early 83 NA Fuel Rail Needed
I could Really use a fuel rail since mine leaks and ive tried patching it several times and it still leaks. Ive got the funny rail where the fuel line connects to the damper, then from the damper to the rail, and the other connection is from the rail to the regulator and the regulator to the return....
so IE there are only 2 connections on the rail... i say this bercause i have tried replacing the rail but ended up with a rail with three connections and didnt know what to do with it... it wouldnt connect in the same way... so if anyone could help me, it would be greatley appreciated.
thanks
Greg
thanks
Greg
Lifetime Member
Lifetime Member
Try George at 944Ecology.com or the guys out here in Cal at Partsheaven 1-800-767-7250 . They have lots of used fuel rails. Are your FPR and DAMpner at the same end of the rail or at opposite ends ?
Schlicten,
thanks for the offer but i dont want to take one of your planned project rails if erau has spares. BUT do tell me how the adjustable FPR mount goes, ive been looking in to that, but i dont have the extra cash to throw down for it. Also how did the JET DME work out for you, any improvemetns?
