steam vent still a thing?
Old 03-10-2018, 12:57 PM
jvandyke
jvandyke's Avatar
Default steam vent still a thing?
Running tests today, suspected HG issues. I like the steam vent idea, I don't see a ton of recent chatter on it. Still recommended?
Old 03-10-2018, 04:21 PM
Tom M'Guinn
Tom M'Guinn's Avatar
I have no regrets. Hard to say if it helps preserve gaskets, but it self-vents the system, so that's a good thing in general and makes for less of a mess in the garage.
Old 03-10-2018, 10:25 PM
fejjj
fejjj's Avatar
Agree with Tom here!
Old 03-11-2018, 01:42 PM
David Floyd
David Floyd's Avatar
Agreed....even if the self venting is the only positive, well worth it
Old 03-12-2018, 02:19 AM
Chalt
Chalt's Avatar
Googled steam venting and a lot of links about LS engines. What is steam venting in a nutshell?
Old 03-12-2018, 09:05 AM
jvandyke
jvandyke's Avatar
tapping the head to the water jacket to add a port behind the 4th cylinder to allow coolant/air to circulate back to the reservoir, lets air out of an area that is prone to trapping it, trapped air can cause the head gasket to blow, air in the coolant system causes lots of head aches, this mod helps with it, if I were pulling the head I would do it, I don't think I have to after all, yet.
Old 03-12-2018, 09:08 AM
jvandyke
jvandyke's Avatar
https://www.lindseyracing.com/mm5/me...Code=STEAMVENT
Old 03-12-2018, 09:54 AM
KEVIN ANDERSON
KEVIN ANDERSON's Avatar
Yes I have used it on the past 2 heads that I have rebuilt and installed. It really isn't a steam vent. Once the engine gets up to temperature it becomes a path for the coolant to flow. The hose is clear so you will see some steam at first then release some pressure and it becomes a solid flow of coolant. Definitely worth the little bit of work and small price for the kit. It's nice to know that the entire head is being completely filled with coolant and it's flowing nicely.
Old 03-12-2018, 10:08 AM
jvandyke
jvandyke's Avatar
yep, bit of a misnomer, "coolant bypass" maybe a better name? I'm not doing it since the HG seems fine after all but the only concern for me is added plumbing and potential failure points introduced, more hoses and clamps=more possible issues, bursting that vent hose as it runs across the engine would not be good but if done well, I suppose pretty unlikely.
Old 03-12-2018, 06:23 PM
Wisconsin Joe
Wisconsin Joe's Avatar
One more pile on:
The back of the head is a bit of a dead end for coolant flow.
The only way it really gets circulation is into the heater core.
So if you are running a car that never gets the heat turned on, running it hard has the potential to develop a 'steam bubble' towards the back. Many race car setups delete the heater core and run hard.
That can be really bad for the head gasket.
The 'steam vent' is just a circulation path to get the coolant out of the back of the head.
Old 03-12-2018, 06:34 PM
V2Rocket
Rainman
V2Rocket's Avatar
^^ delete the heater, just loop the coolant outlet on the head, around the back of the cam tower, to the return pipe over the exhaust going back to the pump..
Old 03-13-2018, 11:07 AM
mazdaverx7
mazdaverx7's Avatar
If this is something that is only being used when bleeding the cooling system, why not save the work and invest in an Air Lift coolant bleeder
Amazon Amazon
. I use one at work and it removes all air from the system using a vacuum and will fill the cooling system leaving it free of air pockets. It works great and I've never had an issue. Just throwing in my opinion here.
Old 03-13-2018, 11:14 AM
jvandyke
jvandyke's Avatar
Ever been to Michigan? Heat is pretty much a necessity, even on a seasonal toy.
Old 03-13-2018, 11:15 AM
jvandyke
jvandyke's Avatar
it's meant to be left in place and continual, always "venting"
Old 03-13-2018, 12:37 PM
V2Rocket
Rainman
V2Rocket's Avatar
no, minnesota though!
but my comment was in response to the previous poster talking about racecars specifically who delete the heater core altogether.
Quick Reply: steam vent still a thing?
