"Floating" Idle question
I am kind of at a loss. My idle (adjusted correctly) floats by 50-100rpm every couple of seconds. I had this problem ever since I bought the car from an impound yard. Since then I replaced:
- fuel pump and return check valve (new)
- fuel filter (new)
- fuel pressure regulator (new)
- fuel pressure damper (new)
- fuel injectors and seals (new)
- Cap, rotor and wires (new)
- Vacuum hoses (new)
- Intake manifold gaskets (new)
- Oxygen sensor (new)
- DEE (DME, ECU or whatever they call it) (from another working car w/o the same problem)
- Fuel pump relay (used)
Installed:
- cone air filter
- new aftermarket cat and exhaust
By looking at the mass airflow sensor (whatever it is called) needle under the plastic cover, the amount of air coming in stays constant, therefore, the MAF most likely is not a suspect.
The problem remains. It does not seem to adversely affect the performance of the car. I am thinking idle speed controller – big bucks for a little improvement. Factory manuals say there is a way to disable this device (by shorting terminals A and C on the diagnostic port). The pictures show the plug located near the battery (bolted to the side of the car with bolts just ahead of battery). I don’t have that! If I did a sure way to check it would be disable it’s operation and see what happens.
Any ideas of the problems itself or the diagnostic ports will be appreciated.
Thanks.
- fuel filter (new)
Installed:
- cone air filter
Thanks.
Ask what changes the idle. Air bypassing the throttle body.
Where can air bypass the throttle body? Any of the large and small vacuum lines that are on the engine side of the throttle body. Also there is a large o-ring between the throttle body and the intake manifold as well as an o-ring around the idle adjustment screw.
Why does your cars idle fluctuate? The DME is controlling the idle bypass valve and keeps trying to reset the idle. You can over ride this by jumping from pin B to pin C at the test plug. This makes the DME center the idle control valve. You use the large screw on the throttle body to set the idle.
With the idle control valve out of the loop see if your idle fluctuates. If it does then start thinking vacuum leak. Possibly the brake booster fitting or any of the other large vacuum hose connections. Don't exclude the o-rings.
SoCal - thanks for reply. I recall now, that when I move it just right, I hear the hissing sound where the large hose connects to the brake booster! How easy is it to replace that fitting?
A sub-question - where is the diagnostic port? My car seems to missing it, but I have an empty plug near the firewall ziptied to the engine lift point - is that it? if so how do I identify terminals A and C. Thanks.
SoCal,
I have seen this picture in the factory manuals. I can't find the port anywhere! Could you point the location of it on the car. I looks like battery compartment, but apparently not.
Sorry to keep asking, thanks.
Sasha,
The connector is on the fender of the driver's side by the brake booster. You might be overlooking it because it has a plastic cover over the top of it and it does not look like the picture until you pop off the cover. It is hinged and the plastic is old, so pry it up carefully. At least this is where mine is on my '87 and I had a hard time locating it the first time.
Thanks a whole bunch. I did see it - you are right, Rodney, it doesn't look like a anything electrical , but rather vacuum related. What an exotic place to put a diagnostic port....
Thanks.
Thanks.
I didn't adjust the idle, a local shop did. I did mess with the adjustments on Air Flow sensor. I think I put them back where (the same) local shop had them after smogging the car. I just assumed, the idle is adjusted properly because I trust the shop (Prescision Motion/Kravig Engineering in Riverside, CA). I do know how to do it now after reading the manual. I think the BS with O2 measurement is just for emissionsions. If I had to do it myself, I would just bypassed the idle stab. and adjusted the idle by ear and tach in the instrument cluster. I would then lean out the mixture as much as I can w/o adversly affecting the performance.
Thanks.
Thanks.
