911 Turbo (930) Forum 1975-1989
Ltd slip rear diff noise
Old 05-30-2001, 10:02 AM
Josh Pinkert
6th Gear
Josh Pinkert's Avatar
Post Ltd slip rear diff noise
My differential seems to cause the car to make a shuddering/buffeting noise when I'm moving slowly and making tight turns (parking lots, etc). Is this a sign to replace the tranny fluid? Is swepco good for the 930 tranny?
Old 05-30-2001, 12:26 PM
john walkers workshop
john walkers workshop's Avatar
Post
LSD diffs need GL-5 lubricant, or they are noisy as described. kendall makes an additive to be used with GL-5 for LSD diffs.
[ 30-05-2001: Message edited by: john walkers workshop ]
Old 05-31-2001, 08:53 PM
Jason @ Paragon Products
Jason @ Paragon Products's Avatar
Post
Your hearing limited slip "chatter". Like John mentioned, you need a GL5 lube that has a limited slip additive/friction modifier. Swepco 201 has the additive as does some of the Red Line products and others.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Old 06-04-2001, 10:33 AM
Lane
Lane's Avatar
Post
Yes, SWEPCO 201 gear oil is GL-5 rated. I use 201 in my '79 930 transmission and in my G-50 transmission . One of the listers wrote that he was having a problem with his G-50 tranny not shifting correctly when it would get hot at a DE , he was using a name brand synthetic at the time, but switched to 201 and cured the problem . We are also using 201 in the new Shelby Series 1 , it has a stiff shifting problem with the modified ZF transmissions in those cars.
Old 06-05-2001, 05:19 PM
Josh Pinkert
6th Gear
Post
Thanks. I'll swap it out in the next few weeks. Any idea if having incorrect fluid in for 10K miles will do any damage to the diff?
- Josh
Old 06-08-2001, 10:12 AM
Lane
Lane's Avatar
Post
As long as it's a GL-5 rated gear oil you should be fine, and if your really concerned about your tranny don't put it under a lot of stress until you get the best oil in it.
Old 06-16-2002, 07:33 PM
BrianKeithSmith
BrianKeithSmith's Avatar
Post
Which Weight of Swepco 201 should be used in my 930 transmission?
I do not drive it on the street much any more, mostly on the track.
Looks like there is an 80w90 and 80w140 weight.
Which one for me?
Also, if I drain my tranny, how much will it take to refill it? I've heard to fill it until it is just at the point of flowing out of the fill hole? Correct? But will that be more than a gallon? Or should I order 2 gallons to be safe?
Thanks,
Brian
Brian
Old 06-16-2002, 10:08 PM
Geoffrey
Geoffrey's Avatar
Post
fill it until it comes out the fill hole. One gallon will be enough.
Old 06-17-2002, 08:44 AM
BrianKeithSmith
Post
Which weight of Swepco 201 though?
Old 06-19-2002, 08:05 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Post
[quote]Originally posted by BrianKeithSmith:
<strong>Which weight of Swepco 201 though?</strong><hr></blockquote>
Use the 80W-90 and you'll be just fine.
BTW, if you have a stubborn LSD, GM & Ford both make an excellent LSD additive in a small bottle that can be added to the transmission to eliminate LSD plate chatter. Its really super stuff.
Quick Reply: Ltd slip rear diff noise
